timo888 wrote:Would a viscous liquid flow at a different rate through a filter comprised of simple cylindrical channels than it would through a filter comprised of channels that opened out like the bell of a trumpet, if the total effective filter hole diameter on the near (in) side of the filter were the same and everything else were identical?
If we called the image on the left example A, and the one on the right example B, I would guess that the expansion area in the bottom hole would allow larger bubbles to be formed in the crema, which would tend over time to merge and dissipate depending on the oily surface surfactants of the bean and roast in question.
In example B, I would expect a much more turbulent outflow in the area of each hole, and this would induce micro mixing and a more emulsifying effect of the gases in the outflow. As smaller bubbles would take longer to recombine I think a longer lasting crema would result.
This is only a guess based on basic physics, so YMMV.
Once again a long test period would be the only way to get a result, unless there was a obvious taste difference.
-Cecil
