RapidCoffee wrote:The same observation applies to any study, including your work comparing vibe vs. rotary pumps. I could point out that your results apply only to your Cimbali Junior espresso machines, whatever grinders you used for the study, and that particular batch of beans. Ditto for your more recent article on freezing greens. But those studies are still valuable, providing (at least) a starting point for future investigation. That's all I'm suggesting here.
John, I think this analogy doesn't really work. Particle size distribution, although very interesting, is an observation, not an end point. I would define the real end points here as shot quality and consistency, plus usability, the latter being almost entirely subjective. The interaction between particle distribution and the real end points are to my knowledge, as yet unknown.
The fact that particle size distribution on a SJ might be effected in XYZ fashion when the grinder is used hopperless, has no known relationship to what happens to the particle size distribution on a Kony or Robur when used hopperless, unless this has previously been defined, which I doubt. The risk is that real differences among the grinders may be obscured, because some of them function better hopperless than others, which might not relate to how they work with a bean load on top. This could easily give the appearance that there is no difference between the grinders when in fact, when operated with a bean load, there would be. And as before, the particle size distribution has an undefined relationship to the real endpoints.
In contrast, the studies I've done on Cimbalis and on Freezing were controlled experiments with balanced variables. Like any such study they are open to question and would need to be repeated by other investigators if the results are desired to be confirmed. I think it is a bit more likely that all freezers do more or less the same thing to coffee, whereas less likely that hopperless operation of grinders has the same impact on all grinders. But I could be wrong
RapidCoffee wrote:All the Titan grinders are more than capable of producing excellence in the cup, so to some extent we're talking personal preferences rather than better or worse. Good grind quality and ergonomics are to be expected from grinders in the $1K price range, and I think the Titans deliver.
I'll be pleased if we reach consensus on a few general issues, such as fundamental differences (if any) between flat/planar burr grinders and conical burr grinders. (And perhaps dispel some of the recent hype surrounding conicals.) The TGP testers (Dave, Jim, Ken, Dan, and I) have all noticed the high forgiveness factor associated with conical grinders, and that may be one of the most compelling conclusions of the study. Tastewise, there's less consensus - neither Dave nor I are rushing out to buy a conical just yet.
I appreciate the plug however I'm not on the TGP panel, and have only been pressed into service around the edges by Dan, and that long after this project was conceived and started.
ken
