Is it OK to backflush with TSP?
Postby lemurofdoom on Fri Apr 03, 2009 5:11 pm
I understand most of the commercial detergents use TSP (trisodium phosphate) as a key ingredient.
So, my question is: In a pinch, is it OK to backflush with TSP? Is it safe? Is it effective? In other words, if you had TSP on hand (but no detergent), and you needed to backflush immediately for whatever hypothetical reason, would it work (remove oils, gunk etc)? and would it be safe, providing one flushed sufficiently afterwards?
I've found some suggestion here and there that it's OK, but nothing definitive in terms of real consensus or an official source.
Thanks!
-dan
lemurofdoom
Postby another_jim on Fri Apr 03, 2009 5:25 pm
As far as I know it's fine. The regular back flush detergent is mostly TSP, and it's soluble, so will rinse out afterwards. I think the espresso machine stuff has a little foaming additive to make it more dramatic.
another_jim
Postby DavidMLewis on Sat Apr 04, 2009 7:53 am
So far as I know, it should be safe. But the commercial products also contain a lot of enzymes to improve the cleaning. My understanding is that they're sort of like amped-up dishwasher detergent.
Best,
David
DavidMLewis
Postby lemurofdoom on Sat Apr 04, 2009 3:13 pm
just to clarify (since someone was actually kind enough to email me an offer that i could stop by and pick up some detergent from him locally here in chicago)... this is only a hypothetical question... i DO have cafiza on hand, and backflush with it regularly... i was kind of just curious, having read some talk about it from various sources... a couple people seemed to think it wasn't a good idea, while most are saying it should be fine.
i think the consensus seems to be it's ok but maybe not quite as effective.
lemurofdoom
Postby Ken Fox on Sat Apr 04, 2009 6:02 pm
lemurofdoom wrote:just to clarify (since someone was actually kind enough to email me an offer that i could stop by and pick up some detergent from him locally here in chicago)... this is only a hypothetical question... i DO have cafiza on hand, and backflush with it regularly... i was kind of just curious, having read some talk about it from various sources... a couple people seemed to think it wasn't a good idea, while most are saying it should be fine.
A consensus formed of opinions from people who aren't really sure, isn't worth much. I'd be surprised if it did any damage, however the real stuff isn't so expensive that it would be worth bothering with.
ken
What, me worry?
Alfred E. Neuman, 1955
Ken Fox
Postby iginfect on Sat Apr 04, 2009 7:21 pm
Having a B.S. in chemistry 42 years ago and not working in that field, I think its ok. However,TSP is sort of an environmental nono and most "TSP" I have searched for locally contains some unlabeled chemical in its place. Whatever it contains probably isn't safe to ingest.
Marvin
iginfect
Postby cannonfodder on Sat Apr 04, 2009 7:48 pm
I have yet to see any backflush detergent that was safe to ingest. You have to flush well after the detergent. You would also want to pull a garbage shot to make sure everything is cleaned out and re-season the group.
cannonfodder
Return to Tips and Techniques
