Hi there,
You can use the data in Jim's insanely long water FAQ to calculate the acceptable level of hardness and alkalinity for your machine, using the datasheet on your spring water or by testing the water.
You can then test your water using tests kits sold for aquariums (the ones with drops of chemical you put in a test tube of water) to fine tune your mix.
For example, i use RO water mixed with some tap water i've filtered with a charcoal filter (for getting rid of funny tastes). I mix in just enough tap water to keep it below the limit for boiler safe water. In my case, it's 3 parts RO and 1 part tap water, our water is moderately hard. At these levels, your autofill and low water probes will be happy. I also have a Rocket.
I test every 3 months to check for variations in the tap and RO water. The RO water comes from a local food mart and is quite cheap. That way, i can prolong the time between descales and while maintaining an ok level of minerals for taste.
It sounds complicated but it's not once you've done the initial chore of setting up your ideal mix. And, you eliminate the need and cost of getting spring water.
Here's the link.
http://web.archive.org/web/20080526072324/http://www.big-rick.com/coffee/waterfaq.htmlThe other route is to use harder water for optimal test but live with the PITA that is descaling a HX on more frequent basis.
