dsc wrote:Things I did not like was the hand trick with the coffee which might suggest you should do the same and confuse people, the '30lbs of pressure' tamp and the redistribution which is not always necessary (preheating the cup probably falls under the same category). Besides those technical bits (everyone has their own prep technique) the main thing that was omitted was the coffee itself and the importance of good beans. Without that even super fine feeling grind won't get you anything.
1 - the "hand trick" is valuable and useful to learn.
2 - 30lbs of pressure for a tamp is considered by many a good idea with some coffees in order to get a specific style of shot - but what is more important is that it be consistent (ie "30lbs" rather than "just push on it in some way").
3 - distribution IS necessary unless you are using a modified Anfim or something of the like. Yes... I know you disagree. But you need to accept that you are a tiny minority on this one. If the video only showed things that EVERYONE agreed were true - it would be less than 1 second long and would show perhaps a quick flicker of a coffee bean before it went black.
4 - preheating the cup is best practices unless you have one of a few machines which keeps cups on top of it very warm.
5 - its a promo video from a very high end coffee roaster designed to sell their coffee. I think the obviousness of needing good coffee shouldn't have to be made even more present.
Still I think it's a good vid, not too technical which would probably drive people away, but not too vague either.
dsc wrote:Oh one more thing, don't you need to preheat the group on the GS LMs before pulling a shot if the machine has been sitting idle?
No. It's a saturated group, not an e61 type.
