i also have a silvia V3 and i am fairly recent to making capps and lattes at home. i've had the silvia since last may (2010) and have been training pretty hard since then. i have also read many words and watched many videos about how to get the microfoam happening and it was all very hit and miss for me until about the last month and a half, when i have stumbled onto a fairly consistent way to get at least decent, and usually much better than decent, microfoam from the silvia.
what i have stumbled on is contrary to some of the things that i have read and watched and i am convinced that there is more than one way to skin this cat, but this is what has worked for me with the silvia. i have tried a lot of different variations and nuances but one thing has made a bigger difference than anything else, and that is starting to steam at the right time in silvia's boiler heating cycle so that i have maximum steam output.
what i have noticed is that i get really mediocre results (something like how your pictures look) when i don't have enough steam pressure
which then forces me to keep the tip too close to the surface in order to get any foam at all. this is what i think is your primary issue. you need to get the tip down a little bit deeper, BUT, this won't seem right and won't work at all UNLESS you have the silvia pumping out steam at the max it can.
additionally, without enough steam pressure, the milk doesn't really get stirred adequately in the "texturing" phase and that resulted [for me] in the kind of separation between liquid milk and foam that i can see in your picture in the clear glass.
when there is enough steam pressure, you can keep the tip down a little lower and the natural wavy chaos that is created in the pitcher with lots of steam will automatically introduce air in the right way to create the microfoam. it sort of just works.
so here is what i do as best as i can describe it:
- half-fill a 12-oz pitcher with whole milk and put it in the freezer
- grind, tamp, and pull my shot and put the cappa cup on top of the silvia to stay warm. as i am turning off the espresso flow, i am turning on the steamer switch.
- after about 20 seconds, i bleed out all the water in the steam wand, until it starts to weakly spit some steam. then turn the valve back off and wait.
- while waiting for the boiler to get up to temp, i dump the extracted puck and clean up the portafilter
- when i think it is getting somewhat close to max temp (timing intuition developed over the months), i take the pitcher out of the freezer and set it near the silvia.
[now here is something that is a little different from what i have read and seen on the net: i wait until the boiler light goes out. many people will say that it is better to start frothing before the light goes out so that the boiler keeps heating. i have tried that (a lot) and all i can say is that it hasn't worked as well for me as waiting for the light to go off.] - the moment that the light goes off, i immediately blast out any remaining water in the wand into the tray (1 or 2 sec blast), then turn the valve back off, bring up the pitcher and position the tip a good inch below the surface RIGHT IN THE MIDDLE OF THE PITCHER (i have tried it off on the side and it works, but for whatever reason, the middle is working better for me more consistently), then i turn the steam on pretty high (which is maybe 3/4 of a turn to a full turn or so).
- as soon as i turn on the valve and the surface of the milk starts to roil, i then raise or lower the pitcher to keep the milk really roiling with a very occasional tcchhrrp sound. there is a really good size standing wave on the surface and all of the milk is getting moved around really rapidly. this intense "roiling" of the milk is the one and only observable thing that i can consistently associate with good microfoam from the silvia. you cannot get this kind of action in the pitcher unless the silvia is at pretty close to the max steam pressure that it can do, and i think this is one of the main things that makes frothing a challenge on the silvia because you have to time it right. honestly though, when you hit the right timing so the pressure is high, it's pretty easy to get the microfoam.
- i don't have a thermometer, so i can't tell you what actual temp is in there when i stop "stretching" and push the tip down a little further, but the side of the pitcher is pretty warm. at that point i push the tip down really just a tiny bit lower -- maybe half an inch or so, and really work on keeping the roiling of the milk going as best as i can. again, with good steam pressure this is not so hard to do. you are slightly tipping the pitcher this way or that until you get good movement and then you just hold it steady there as the foam mixes in and the milk volume expands a bit more.
- when the pitcher is too hot to touch and the sound starts to deepen, i turn off the steam valve and wait a second or two for it to completely stop.
- then let it rest for 10-15 seconds, a couple raps on the counter and a little bit of swirling (not much really) and it is so pretty.
some days are still better than others, but that routine gets me at least passable microfoam every time now.
to reiterate, my guess is that you are too much on the surface of the milk which is what creates that sea-foam with the big bubbles, and in my case, when i was having that kind of problem, it seems to me that it was because i was not getting enough steam pressure out of the silvia and that forced me to stay on the surface to get any kind of foam / froth at all.
my "breakthrough" came when, a couple times, i let the boiler heat up [what i thought was] "too far" until the light turned off and there was way more steam pressure than i was usually getting and it ended up making the microfoam production almost effortless (and also very fast).
after the months of banging my head against this particular wall, i sincerely hope something in here helps you on your way.
