Dieter01 wrote:
So the question... If you only fill a double basket with 14g, which is less than flush with the rim, how do you level?
Weigh what you grind on a cheap but accurate 0.1g scale, like this one:
http://www.dealextreme.com/details.dx/sku.1165
I dispense the grinds into a ramekin, with the scale "tare"d to the weight of the ramekin, but any small vessel including the Portafilter itself will do. I will use any quantity within 0.2g measured weight of my target dose (14g for me, so I'll use 13.8 to 14.2g). Any more or less and I'll either add or remove what is needed.
I spoon the grinds into the PF basket, which generally takes 3-4 teaspoonfuls, then knock the rest of the ground coffee into the basket from the ramekin. My only other basket preparation prior to making the shot is to twirl a tamper in the PF basket for 2 seconds. I then lock and load the PF in the machine and pull the shot. I don't make any particular effort to distribute or level, however with this dose it seems to happen more or less on its own with the technique I use.
If I am making 2 shots in the same session (i.e. one for me and one for someone else), I'll try to weigh out something approaching 28g, spoon 14 into the PF (using my superior mathematical calculation skills
), then finish what is needed from what is left for the 2nd shot. I would probably not grind for 3 shots in succession at one time, as I'd rather use grinds fresher than what I'd have left for the 3rd shot.
That's it.
ken
