thefly wrote:I have so far been unsuccessful in getting my spout off my PF to build a pressure gauge so I tried this test instead.
My question is, when do I start my timer, when I press the brew button or when water first starts flowing?
To get the spouts off, I usually find a doorway that is somewhat out of the way, possibly and exterior door, and preferably one for a shed of garage that gets a bit of smacking around already. Open the door, and go to the jamb at the back of the door, on the 'outside' (the part where the back of the door opens away from the jamb). Place the spouts between the door and the jamb, and use the door as a great soft wrench, being careful not to apply too much pressure. Remember, you're not trying to squeeze the spouts, just not allowing them to spin out. Use the PF handle to (lefty-loosey, righty-tighty) unscrew the PF from the spouts.
Pay close attention to the instructions that you quoted. The suggestion was that you start the watch at two ounces, and stop it at four. This gives Silvia two ounces to settle in and get to business.
Good luck!
