Paul,
Nice to have a pro like you in on this discussion. I can see that you're offering a good-tasting alternative but am a little confused with your description of cold toddy so am writing for clarification. Are you saying:
- That brewing below 68 degrees F doesn't extract cafestol and kahweol? (Can you point us toward supporting studies? Add: Or a chemical reference about the properties of these two chemicals to support this idea?)*
- That because there's no paper filtering, tasty organics remain in the brew and provide a superior taste profile to paper-filtered espresso?
Also, you're distinguishing the cold toddy from espresso so it lacks crema and has about the lighter extraction ratio of an Americano?
* To my limited knowledge, paper filtering of cafestol and kahweol has not been tested for brewing under any more pressure than in an AeroPress, so personally I'm hoping that such filtering helps somewhat in espresso. Previously I was paper filtering after the shot and had great cholesterol readings so am willing to take a little risk for better taste and mouthfeel.
