How to Make Decent Paper-Filtered Espresso - Page 4
Postby drgary on Thu Jul 28, 2011 3:30 am
I wonder if just slipping a paper filter into the PF is as efficient as other methods where you know there isn't leakage around the edges? Until this is measured, for health purposes, I think I'll keep doing the filtering after the fact so there isn't that leakage.
LMWDP#308
drgary
Postby RapidCoffee on Thu Jul 28, 2011 11:15 am
Why would there be significant leakage? That seems unlikely. There is ~9bar pressure forcing the coffee puck against the paper against the bottom of the filter basket.
I'd be more concerned about espresso brew pressure forcing more lipids through the paper filter, compared to drip or AP brewing.
John
RapidCoffee
Postby drgary on Thu Jul 28, 2011 11:30 am
You're probably right and I do have the second concern. Thanks.
LMWDP#308
drgary
Postby cafeina on Tue Aug 09, 2011 4:22 pm
drgary wrote:You're probably right and I do have the second concern. Thanks.
I tried cutting a few paper filters and using them. I first loaded a paper filter into the
PF and ran water through it. I have a 4 sec pre-infusion set on my machine and them
the volumetric dosing runs about 1.5 oz of water. To my surprise, the paper filter did
little to impede the flow of water. I didn't appear that the paper filter moved or slipped
at all when I looked at it. It was nice and flat (like a film) across the bottom of the pf.
It didn't seem that there was much back-pressure added to the process by adding
the paper filter. Even if it filters out 20-30% lipids, at least that's something ... as long
as you like the overall result. :)
cafeina
Postby drgary on Tue Aug 09, 2011 5:30 pm
I think I'll have to cycle back to Ken Fox's suggestion and get my cholesterol panel drinking espresso filtered this way versus coffee made in an AeroPress, where the pressure is low and the filtering effect has been well demonstrated. That should give me a good read. I'll report back if I get that done.
LMWDP#308
drgary
Postby dsblv on Wed Aug 10, 2011 10:28 pm
cafeina wrote:I tried cutting a few paper filters and using them...To my surprise, the paper filter did little to impede the flow of water. I didn't appear that the paper filter moved or slipped
Agree 100%. I've been using hand-cut coffee filters in my portafilter for about 6 months. I alternate between Melitta and Aeropress filters. The filter doesn't impact pulling the shot. The flavor of the shot is a little muted compared to not using a filter. But, I make lattes and don't notice the difference in my drink. Even if the filter helps just a bit, I feel this is worth doing.
dsblv
Postby drgary on Thu Sep 08, 2011 6:00 pm
Now that I've started putting filter papers in the basket and worrying less about how this may affect my cholesterol measurements, I just read a new thread that (only) suggests changing how coffee is dosed and ground when using those papers. It's an admirably technical piece of research done primarily by Jim Schulman with contributions by others in the HB team. Here's the link to it:
How filter baskets affect espresso taste and barista technique
After a first read, I gather that different baskets with different amounts of perforation and differing levels of uniformity of the holes affect the taste of a fresh, hot shot with crema, specifically that baskets with holes engineered to finer tolerances and allowing faster flow because of more cumulative holes tolerate a finer grind up to a certain dose and thus allow more structure in the flavor of the shot while somewhat taming the intensity. Too high a dose at this finer grind, and the shot is unpleasantly intense. I think I'm interpreting that correctly. Here's a quote from Jim on what he means by structure and taming unpleasant characteristics of such more intense, higher-dose shots:
another_jim wrote:The higher the dose, the punchier tasting the shot. This punch is a combination of astringent, cutting and bitter flavors that wine lovers get from tannic wines, and which they call "structure." The higher the dose, the more structured the shot; the lower the dose, the creamier and softer tasting the shot. Since this effect disappears as the crema dissipates; this structure difference is clearly caused by differences in the crema of high and low dose shots.
Italians like soft and creamy espresso; but Seattle and West Coast espresso typically has a lot more punch. Five years ago, West Coast blends were medium roasts and had low acidity; and one could get away with overdosing a double basket and grinding coarse. With the advent of more acidic and brighter SOs and blends, the choice with a conventional double is to grind finer, dose lower, and give up the punch; or to make a very rough shot with coarser grinds and higher doses. The VST 18 gram baskets uses the same grind as a conventional double at 15 grams. This means it delivers the high dose structure without the unacceptably rough and sour taste of under-extracted, lightly roasted coffee. This may explain why some people strongly prefer the VST18 or Strada baskets.
Another finding in that thread is that baskets with more holes that are more finely engineered are more sensitive to variations in dose, such that consistency is difficult to achieve with anything equal to or less precise than a Mazzer Super Jolly grinder.
That thread leads me to wonder whether those of us pulling shots through filter paper may benefit by updosing a bit to achieve more structure while benefiting from a similar taming effect.* Also, I wonder whether paper at the bottom of the basket makes the brewing technique more or less tolerant of inconsistencies in lesser grinders. In other words, are excess fines (randomly small particles) less of an issue when filtered out by paper? I am not suggesting that filtering espresso through paper is a way to optimize flavor over dispensing with the paper and using only a metal filter basket. This is for those of us willing to compromise flavor somewhat for a healthier brew (but further discussion of that is off-topic for this thread).
I believe that those of us who are interested in paper filtering of espresso are relatively small in number and doubt that there's to do similarly rigorous testing. But I personally want to start with updosing some filtered shots and tasting them against lower-dosed shots without filter paper. I'll be interested in others' responses to the thread on filter basket differences as to whether it applies to pulling espresso through filter paper.
* I'll concede that my expectations may be "off" because the effect of pushing espresso through the tiny holes in paper could bring into play very different effects than pushing it through the larger holes in a metal filter basket. Why? The filtering effect may be very different with the smaller and possibly more varied holes in paper, especially with regard to substances such as lipids clinging to each other at one side of the paper. I also concede that I am not yet even considering the effect of differences in filter baskets when pulling espresso through paper. And, I acknowledge that I don't have the scientific training or the cupping expertise to test or analyze this subject with anything like the rigor that Jim Schulman and other HB members applied to their filter basket study.
LMWDP#308
drgary
Postby iginfect on Thu Sep 08, 2011 8:55 pm
I cannot comprehend why anyone would be concerned about cholesterol in espresso when they are adding steamed animal fat(milk) to their espresso drink. If you are that concerned, leave out the saturated cow fat. The espresso stands by itself.
Marvin
iginfect
Postby coffee.me on Thu Sep 08, 2011 9:15 pm
iginfect wrote:I cannot comprehend why anyone would be concerned about cholesterol in espresso when they are adding steamed animal fat(milk) to their espresso drink. If you are that concerned, leave out the saturated cow fat. The espresso stands by itself.
I'm a layman, and the way I understand it in layman terms is simple: while espresso (without milk) doesn't add much cholesterol to your diet, it has compounds (Cafestol & Kahweol) that are making some people's bodies maintain higher blood cholesterol levels.
So, the filters aren't to take out the cholesterol, they are for the other stuff...it's all in my 1st post of this thread.
For a more thorough discussions on the health part of this, have a look at:
The effect of espresso drinking on cholesterol
Paper-Filtered Espresso and Cholesterol
"Beans before machines" --coffee.me ;-)
coffee.me
Postby drgary on Thu Sep 08, 2011 10:42 pm
+1
As noted above this thread is for making decent shots with filter paper. I'm trying to get back on topic instead of continuing discussing health concerns that are covered elsewhere.
LMWDP#308
drgary
PreviousNext
Return to Tips and Techniques
