by JmanEspresso on Sat Dec 26, 2009 3:25 am
I too just switched, from an E-61 HX, to the Vivaldi II.
One of the main things I was getting used too the first week or so, was dosing and distribution. Its a different ballgame on the VII compared to the E-61. Different, but not harder(IMO anyway).
I used to be dosing in the 18-20gr range on the E-61... Doing that right out of the box with the VII, and I was having trouble, getting donut shots pretty consistently. So, I dropped the down down to 14grs, got out my WDT stuff, and, most importantly, focused on a proper side seal. Doing that produced all around great looking shots.. but some blends screamed for more coffee. The past two weeks or so, Ive been in the 15-17gr range with good results.
Compared to the 58mm baskets, you're going to think you don't have enough coffee in the basket.. a 15gr dose is nicely below the baskets ridge, and gives you nothing resembling a puck when you knock it out. I have yet to have one solid puck, but the shots are tasting better then ever.
Ive come to the(possibly premature) conclusion, that the VII is like the Elektra's, in that it likes headspace, and doesn't tolerate updosing like an E-61 does. Looking at the dispersion blocks of the two machines, Im thinking Im correct, in some way at least. But, regardless of the similarity, allowing for more headspace really made things come together for me. VII likes headspace.
On some of the lower doses, I find myself pulling shots a bit tighter and shorter then I normally would have... But the dose is also lower then it would have been. I think the reason why Im tightening up the pull, is to compensate for a lower dose, to get an extraction ratio similar to what I got with a higher dose. In any case, it seems to be working nicely.
A 0.1gram scale is a nice investment, one that should run you $20 at the most. Amazon and Ebay have plenty to choose from. absolutely invaluable when it comes to dosing consistently.
The VII is an awesome machine to work with, and a TON of fun. Once you get the shots running right, I think you are going to enjoy your setup very much. The temperature adjustment is addicting, and the steam is abundant. Youll be pulling great shots in no time.
