another_jim wrote:I admit this is based merely on logic, rather than direct experiment.
Again, I won't need to participate in a double blind three way to figure out that if my grounds are damp inside my grinder, it's gonna be harder to clean next time I go through it. In addition, I'm way hip to humidity changing the grind that I use, so I'm pretty sure that dampness applied right to the bean during grinding is going to change things too.
I don't need proof beyond a reasonable doubt, nor do I need documentation of experimentation like I'm defending a thesis, to know that adding water to my puck isn't going to be helping me out any. I'm just 'splainin' what happens to my coffee in my kitchen.
Yesterday, that same thermometer on the porch showed 93F and we had 28% humidity, rising to rainfall for a few minutes.
The last post on the weather here was changing so rapidly that by the time I went and pulled me another cuppa, the temp was down to 86F (a drop of fourteen degrees in less than fifteen minutes) and the rain lasted as it does here, for less than that.
Humidity may not be and issue in your air-conditioning (or heat, I guess, this time of year), but it still does present and actual detriment to pulling great shots here in the SW. I'll give y'all a great experiment to simulate what'd be like.
Grind a shot as normal, pull it, observing what it looks like, and taste it. Repeat this until you get something you like. Then measure out your next dose ans spray it with a hose. Repeat the last shots grind/dose/distribution technique and let me know if it changes the appearance and taste of the pull.
If it does, then I think that the theory that introducing moisture to the outside of the bean just prior to grinding might be detrimental might hold some water.
