denniskeating wrote:Hello, I am using a Brewtus 1 converted to a rotary pump offering manual preinfusion with the middle position of the E-61 lever.
Greetings Dennis - is this because you adjusted the brew switch to achieve this?
Should I preinfuse until some coffee appears at the bottom of the basket?
That's the "instructions" in at least one lever machine operator's manual I read (Rancilio).
Also, when preinfuse starts it would first take some seconds to fill up the chamber of the E-61 head before water hitting the puck - is that correct?
No, both events are occuring simultaneously. I'm not too sure that 20 psi is sufficient but that would be easy to observe, i.e. can you take a nap or do you need to watch the basket?
Should you run any taste tests, be sure to stick to the same bean.
