darrensandford wrote:I tend to always taste a shot, even if I think it's going to be bad.
As I implied there is some tolerance away from what I would visually perceive as the optimum (relative to the roast/machines and my "ideal").
Say you have a visible air bubble in the crema (I have seen barista in Italy, secretly, gently whirl the caffè in the cup or gently knock the cup on the counter top to get rid of that bubble in an otherwise perfect cup/crema), or crema with the right color but lacking "tiger skin". The first I would just drink. The second I would decide as sink shot, or not, after a small sip.
Very high speed (in case of maladjustment of the grinder or a different espresso blend), blonding, holes in the crema, or too slow extractions (based on visual clues), I would all just dump in the sink.
BTW, I do not mind dumping shots as part of a learning or fine tuning process. Along these lines, I have advised aspiring barista to maybe spend a few hundred of their total budget less on hardware and just buy beans for that money to get to grips with grinder adjustment, espresso machine parameters and develop a good sense of what an espresso blend or SO can do for you (or which parameter to adjust how when sub-optimal results present).
Regards
Peter
