Hi Larry,
I am up in the air with you (6700 feet at the house), and I previously lived at sea level (although I did not know how to do the 'water dance' then). Water boils at 199 F at my house. You just need to get to know your machine and the coffee. For my setup, I run water through the group around 8 sec prior to locking in the pf, which is just past visibly boiling (and well past flash boiling) to pull shots around 200 F, which I prefer for the blend I normally use). The water dance is described here
http://www.home-barista.com/hx-love.html.
I don't have a Scace device nor a temp probe, but I used a cut-down styrofoam cup with a milk thermometer stuck through the side of the cup to learn more about the temp at the group based on flush time. It was not necessarily accurate, but it is consistent (assuming you run the same amount of water, etc), so you can learn how much the temp goes up or down with longer or shorter flush times, then adjust for taste. So, flush for 7 sec., then put the cup over the group and run the water for 10 s and check the temp. Wait for everything to heat back up, flush for 8 sec then repeat. Run several times, going longer and shorter on the flush to help eliminate residual heat effects, etc.
If you don't have one, get a timer. It pays to be extremely consistent with time, since that is the only variable you can use to control the temp every shot. Also, be sure your boiler is not set too high 1.1 - 1.2 bar should probably be the max.
Hope this helps.
Enjoy your experience, James
