ljguitar wrote:Hi Ken
A common misperception is that boiling point is fixed - in fact today at our house with the barometer where it's at, water is boiling at 199°F (92.8°C)
The effect on my shots (while using my naked portafilter) is that a tornado forms, rich, thick & dark. Then about 2/3 of the way through the pull, it rapidly turns into a big fat bubble, distends and expands the ''tornado'' and bursts while still tiger striping. The crema tops 2.5 oz mark in my shot glass, then within seconds is collapsed to being 3-4mm thick.
I have been pulling a blank shot to cool the group while grinding/tamping, and the quality of the espresso itself is improved...but the crema is wonky.
The amount and condition of crema we get (breaks down quickly) has been this way for years, but I've been removing the crema from our shots anyway, and they are really wonderful tasting. The pucks are solid and not breaching, so I concluded that it's the water at the end of the shot heating back up and vaporizing.
What say ye?...
The altitude of Cheyenne is 6155 feet, according to Dr. Google. In order to have a local boiling point of 199F, you would have to be experiencing barometric pressure of 29.15 mm of mercury, which would cause your boiling point to go down to what one would experience at 7000 feet under "more normal" circumstances.
I have just gone to the National Weather Service website for the weather observations for Cheyenne, WY, two minutes ago. THEY state that the barometric pressure in Cheyenne is 29.80 mm of mercury right now, and they give the altitude of Cheyenne as 6158 feet.
Using this online calculator,
http://www.csgnetwork.com/h2oboilcalc.html , the calculated result for your local boiling point is 200.403 F at this point in time. I don't know how you have calculated a local boiling point point of 199F, and if you have observed this on some sort of temperature measuring device, I would question the accuracy of said device.
Using the same calculator and my local figures, the calculated boiling point for my town (elevation 5850 feet; current atmospheric pressure of 30.10mm of mercury), at this instant is calculated at 201.625 F, or roughly one degree higher. I am not having any of the aberrations in my espresso production that you report above.
You can draw whatever conclusions you like from this, however unless you live at a substantially greater elevation than the altitude I cited above (6155 feet), or if your barometric pressure is substantially different from what the National Weather Service reports, I have no explanation for your observations.
ken
