by mitch236 on Sat Oct 09, 2010 1:23 pm
So today, I decided to try going hopperless on my Robur-E. It was easy to bypass the safety feature and so I removed the hopper. I cleaned out all the old grinds and put in 18.5gm of whole beans into the throat and ground. I was able to retrieve almost 18gm of grinds with sweeping the chute and pulsing the grinder. When I tried to pull a shot, I was met with an extreme gusher! Since I wanted to be sure it wasn't caused by some freak old beans left behind (very doubtful), I repeated the experiment, this time with a tamper over the throat (which doesn't really work since the beans are below the burr retaining bolt). Same result.
I thought the Robur-E has a device to guide the beans into the burrs so I was sure this would work but as soon as I put the hopper back on and half filled it with beans, all was back to normal. I don't think changing the grind is the correct answer. Perhaps some sort of tube like Andy's would work but then, I might as well use the hopper.
I guess my question is, did I miss something? I don't really mind using the hopper but I wanted to keep as much of my beans frozen as possible to keep them fresh.
