Jim
shadowfax wrote:John, I've been drifting off on CG and here, but I still check the Look out JonR! thread... I'm always amused and jealous at how perfect all the shots you ever post have been. I seem to remember in your earlier days, before you were such a "big naked sensation," that you suggested the method you and Dan just described and you were criticized quite a bit on CG for a method that "seemed like it would produce very inconsistent results" or something to that effect.
Now I'm starting to feel like I should go to the biochemistry lab and maybe swipe a dissecting needle...
puffinjk wrote:John, could you share the photos you posted of your method on cg? I'm sure everone would find them quite helpful.
Thanks Jim
HB wrote:Ah yes, the Chicago Chop. Before you deride the moniker, recall that Intelligentsia's crew took four of the top six positions at the 2006 Great Lakes Regional Barista Competition.
barry wrote:iirc, not a single Intelly competitor used the Chop at the 2006 GLRBC.
--barry "tech/head judge, 2006 GLRBC"
RapidCoffee wrote:Thanks Nick! Sorry to read about your Valentina woes; hope you can get them resolved.
I do not wish to make overblown claims for this method. If you already have well-developed dosing/distribution skills, it may not help. If your grinder doses in a nice even pattern, ditto. It's probably not going to work well with mid-dose tamp regimens such as JonR's naked triple technique. If speed is your goal, work on Stockfleth's instead (which I've never mastered).
But... if you are having trouble with clumping grounds or uneven distribution, it might be worth a try. I have a couple of old dissecting kits from my biomedical science days; email me your address and I'll send you a dissecting needle. I'd hate to see you turn to a life of crime. Heck, if there's any interest, I'll order a batch and send them out on request. They're inexpensive, but the S&H cost for one would be ridiculous. You're on your own wrt the yogurt funnel (I like yogurt, but not THAT much).
shadowfax wrote:When you were developing this little trick, did you have trouble with side seals? As I mentioned with the regular stockfleth's move that I worked on this weekend, doing a bit of NSEW pushing at the end seemed to fix the problem there, but not so much with the stirring method.
