Cross-posted from coffeegeek.com due to lack of responses (original question at
http://www.coffeegeek.com/forums/espres...ons/549991 )
Hi All,
I'm looking for tips and help regarding technique and equipment. I have the Saeco Via Veneto. As a first attempt to try to make something resembling a real espresso, I depressurized my portafilter. But, I did not replace the reddish O-ring nor did I replace the handle. My set up now seems to look most like this:
http://www.youtube.com/watch?v=1UqDmBS8S7I I am attempting to get espresso that looks like that too...
So far my espresso shot time is very fast. The shot starts of mainly black, becomes paler and yields little to no crema. It is not sour, but is quite bitter and has absolutely no sweetness. I have used store bought lavazza oro pre ground coffee. I assume this is not good enough. I then went to a local café and had them grind me their favourite espresso blend. Later that day and the next two days I tried pulling shots and there was little difference. Still a very fast extraction with hardly any crema. I have reviewed distribution and tamping and tried my best to follow these guidelines: Click Here (
http://www.home-barista.com) . At this point I only have a plastic tamper...I will be replacing that with a proper one soon.
I have learned that grinding right before I pull the shot is important and that the grinder is more important than the espresso machine. I would like to get a Burr grinder but am a student and can't afford $200+ on this so I looked into getting a Kyocera hand burr grinder.
Questions:
1) Is it even possible for me to get a rich, sweet, syrupy shot filled with crema as seen in the youtube video with a via Veneto?
2) Will a Kyocera hand burr grinder yield coffee that is fine enough for what I'm looking for?
3) Can a professional tamper really make the difference over a plastic one, even if I employ the right technique and apply the correct amount of pressure?
4) What kind of coffee yields the best crema? Is it even possible to accomplish what I want by buying whole beans from the supermarket if I get something "high quality"?
5) I don't understand all the youtube videos I see where shots are like 80-90% crema. Is this what espresso is supposed to look like? It's never served to me like that when I go to caffes here in Montreal...
Thanks very much!
