iflawdya wrote:When i took the portafilter off the grounds actually popped out of it.
Oops. I missed that bit.
Still curious about the water exiting the group with the portafilter removed though.
jesawdy wrote:Woah!!! That looks pretty bad!
What happens when you run some water out of the grouphead without the portafilter (please be careful). Does is flash boil and/or blast out of the grouphead?
If so, and it does so for more than a few seconds, I think you either have a bad thermostat, a mis-wired machine, or not enough water in the boiler. Ensure you have the boiler full by running water with the hot water button and steam valve open until you have a steady stream out of the steam wand. (Of course, ensure the steam switch is off too)
