vetallist wrote:The main issue seems to be my tamping technique, as I suspected.
No, probably not, unless by tamping you mean distribution of the coffee in the basket. Tamping, or compressing the coffee in the basket, is one of the least important factors, except that, as Greg says, a level puck is important, and particulaly so with Silvia.
Distribution is critical with Silvia. This means the coffee needs to be evenly distributed in the basket with no gaps or clumps. As Greg suggested, look up WDT (Weiss Distribution Technique) on this site. It's easy to do and I think you'll find an immediate improvement in your shots.
vetallist wrote:Naked portafilter is probably one more piece of equipment that I need to get to see whether I am anywhere close to proper tamp, which I suspect I am not at all.
A naked PF will help you determine if your distribution is good or not. Definitely get one.
vetallist wrote:I don't have a scale to measure exact 14g doses, but my understanding is that this is what Vario should produce in 7-8 seconds of grinding at one of the finest settings. I will now make sure to check that once tamped, the puck is undisturbed once placed in a Silvia. I am pretty sure I've been overdosing in the past, as I've always seen central screw marks on the puck as well as round edges at the sides.
You can't get close enough to the proper weight by estimating based on the grind setting and time. The weight of the coffee at a particular grind and time setting varies with the coffee and sometimes humidity. And while the Vario has the least retention of any good grinder on the market, it does sometimes retain grounds in the chute. Get a small digital gram scale with .1g resolution. They're very inexpensive ($10-$20). You can find them on Amazon. This will help keep those doses small enough for Silvia and will ensure that you're consistent with your dosing from shot to shot.
As usual, Chris has zeroed in on the two most likely procedural problems. The temp is definitely way too high and your distribution probably needs work. The temp is easy to fix. Distribution takes a little practice, but if you go with WDT you'll be on the right track.
I agree with much, if not all, of what Greg says in points 1-5. Small adjustments can make a considerable difference, depending on the coffee, the equipment in use and the barista. But he's right that at your stage of skill development, with the equipment you have, you shouldn't obsess too much about things like temp and pressure, provided you get the PID into a more resonable range (to achieve 195F-200F at the puck) and your machine's pressure has been properly adjusted to approximately 9 BAR at the PF.
However, I respectfully disagree strongly with what Greg says in the last paragraph of point 5 and all of point 6, and here's the best advice I can give you: begin with the coffee. It's by far the most important factor in the espresso equation.
You say that you're using coffee from a local NY roaster. That doesn't mean much. There are lots of small roasters that do a dreadful job with espresso. Further, I'm not at all convinced that you'll get drinkable shots from any Starbucks coffee. They tend to over roast, and if you don't like that flavor none of their coffees will please you, no matter how well you refine your technique and equipment settings.
I do agree with Greg that you should stay away from exotic blends touted on coffee sites. They may be too difficult for you to dial in just yet. You need to find a "forgiving" blend or Single-Origin coffee that's easy to work with. Trouble is, most of the great blends are designed to be heavily updosed (if you do updose, get the ridgeless basket recommended by Gregg -- it'll work well in Silvia up to about 16g.)
When I had a Silvia, I found the easiest coffees to work with were Single-Origin coffees in low doses. I was (and still am) particularly fond of the Ethiopian Ademe Bedane espresso from Terrior in Massachusetts. It's delicate, delicious and pretty easy to work with. It's designed for low doses, 13g-14g, 195F-197F, 1.75 oz in 25 sec. That said, it is bright and acidic, so if you don't like that profile choose something else. Terroir has a nice Kugomoini Kenyan espresso that's a bit more on the chocolate side of the spectrum.
Perhaps others can chime in here with some high-quality blends or SOs that Silvia can tolerate.
