Raw almonds should be soaked overnight in enough water to be fully covered, with some room for swelling.
The proportions are 3 cups of water for one cup of almonds and when I was making it for the first time, I used this proportions also for soaking, but it is not necessary. If you'd want to make more at one time it could even be difficult to keep that proportions.
After soaking, I stirred the almonds in water from time to time and then placed in the fridge:
The next day you put the water with the almonds in a blender and then swirl it until you get a smooth puree:
The first picture shows the puree after a quick whirl with half of the power, then I was adding more power (second picture) until I got what is shown on the third one:
Then you need to filter the milk out from the puree:
with a sieve:
After that, you have almond milk and almond paste. You need to press the almond paste (I used again the same sieve and a spoon) to get all the milk out:
To get the most out, you need to use another sieve, which is finer:
and also need to press small portions of the paste several times and quite hard:
Then add some water (either three cups of water for each cup of almonds, or, if you used more water for soaking the almonds, some more water). So you have fresh tasty milk!
It is best for use after blooming in the fridge for 24 hours, with a bit of stirring from time to time. Carefully add a pinch of salt to taste (but don't add too much!) and it is ready to drink.
Enjoy!!!!
p.s.
don't waste the almond paste!
It is very good addition for baking a cake or on its own roasted with cocoa and oatmeal flakes.
