cafeIKE wrote:What's interesting with circles is the open area between any 3 circles changes as the square of the radius ratio, but the total open area changes linearly for a number of circle to fill a fixed distance.
Intuitively speaking this seems wrong to me because AREA does not change linearly (it changes by a square). In my silly example, there is an area rather than a linear distance and in puckology terms we would be going 3D...
Of course this is just my intuition and I have not done any modeling or calculation but I would imagine it goes kind of like mesh screens might if you were to vary the wire size as well as the grid lattice spacing.
back in the real world, the sticky part is that every particle is irregular so close packing spheres is a "rough" approximation at best
cafeIKE wrote:...the burrs are spaced about 0.25mm and 1 gear wheel tooth changes the spacing about 4%, but the net extraction time could change 10%, 20%, 50% depending on ....
So it would seem that the behavior is not linear with burr spacing. Considering the tiny amounts of adjustment we make this probably shouldn't be surprising. Instead of talking percentages, consider expressing the same thought using microns for burr spacing...
