another_jim wrote:As I said in my response to Ken, the biggest surprise of the TGP is that grinder quality does not equal grind quality, it equals grind consistency.
From a practical standpoint, the above is irrelevant, because few people here are going to repeatedly toss shots until they get a perfect one; they will toss the grossly awful ones but will suffer along with the mediocre to decent ones, at least as regards flow rate and flow characteristics.
Over my 10 years or so experience with Cimbali Juniors and Cadets (among the better, small planar grinders), I needed to change the grinder settings multiple times each week in order to get good shots. Being a home user making 3-5 shots per day (on average), I could have easily tossed 25 to 35% of my shots on the basis of parameter shift on a day to day basis. Back in that era, I was updosing and dosing by sight, making the potential loss of coffee even worse. If you are lucky, the "bad" shot goes in a milk drink, but if you are not and if you are either rushed for time or you just don't want to throw away so much of your precious coffee, you drink most of what you get, regardless, and try to remember to change the grinder the next time around.
If you do decide to act on Jim's suggestion, you still have to make the bad shot in order to know that the "dose" needs changing, rather than the grinder, so that still equals a tossed shot that many will just drink due to the above reasons regarding coffee waste and time. If you have a "better" grinder then you aren't going to notice these differences very often in the first place, so you won't change your dose anyway, if the observation you are using to change your dosing is the flow rate and shot appearance.
Now, with a "stable" of Cimbali Maxs and a Compak K10 WBC, I toss about 1 shot every two weeks, using a gram scale and dosing at 14g. That isn't to say that I drink every shot, but those that I don't drink are either ones where I'm testing out a coffee, or those I don't like the taste of, that on "eye cupping" grounds were good shots.
Taking Jim's argument to its logical conclusion, with a better grinder, does this mean that if we got a good shot with our high end grinder yesterday, but the shot tastes inferior today, that we should change the grind to accommodate a different dose, since the flow characteristics are apt to be unchanged day to day given the better grinder?
I think you have an interesting idea, Jim, which might bear some sort of standardized testing, but in the absence of blinded testing, I regard it as a hypothesis without any real proof. Since most reasonably good tasters could detect the difference between a shot made with 15g and one made with 16.5 (updosed to account for grind changes), I don't even know how you could possibly test this, except with uneducated palates.
Count me as a skeptic.
ken
