by BradyButler on Tue Aug 24, 2010 8:18 pm
+1 on your guess, and previous posts. Hopper level definitely impacts grind.
Having to change up your routine under pressure is no fun. For most consistent results, pick a hoppper level and always use that amount of beans. If you generally make 3 or fewer doubles in a session, only ever put that amount of beans in the hopper. If you need to pull more shots than that, top off the hopper with another couple of scoops after you've ground the coffee for the first two shots. Repeat as necessary to finish your session.
Another possible explanation is Murphy's law. I find that any time I grind way ahead (more than 2 doubles) there will be some adjustment required that will throw off my pull. The universe seems to find this amusing. I guess someone somewhere wants me to grind on demand?
Carolina Espresso Services
"Quality Service for Espresso Equipment"
