dougz wrote:Thanks fellas.. I do think I would have been happier with the Classic as far as external finishing and larger water reservoir.. But oh well, that can be my upgrade down the road.. Or a Silvia..
Neither of these machines would be a real upgrade. You'd just be spending more money on things that don't really make a difference in the cup (i.e. exterior finish, and size of water reservoir). If you're going to upgrade, wait and get a serious HX machine.
dougz wrote:How can I affect brew temp? Doesn't the machine regulate that?
It does regulate temperature within a fairly wide range. You can affect the brew pressure by flushing. This is something I've only experimented a bit with. It's simple to do, but not very simple to explain. Mark Prince has a video on how to temperature surf a Silvia, that demonstrates the process.
Search "temperature surf", and you'll turn up lots of results.
My standard procedure with my Gaggia once it's warmed up and I'm ready to go is to do 3-4 short flushes, usually 2-3 seconds, until the boiler kicks in. Then I lock & load and brew the shot. The purpose of this is to bring the water temperature down to it's lower limit. Other users will have more elaborate procedures (less flushes, or a set time to wait after the boiler kicks in), for dialing in a specific temperature, but this is simple and it works pretty well for most coffees I've tried.
