Good reason for replacing reservoir water?
Is there a good reason as to why I need to be doing this ? I have perfectly fresh water in the reservoir however this quote is mentioned. How can perfectly fine clean water need to be replaced every other day. I dont see the need for this.
Espresso Machine Cleaning - Why, How, and WhenReminder: In addition to replacing the water in the reservoirs of pourover machines every other day
- boar_d_laze
Because a liter or two of water in a loosely covered container doesn't stay "perfectly fresh ... [and] clean" for more than a couple of days. It not only goes flat, but supports interesting bacterial colonies.sonicd0012 wrote:Is there a good reason as to why I need to be doing this ? I have perfectly fresh water in the reservoir however this quote is mentioned. How can perfectly fine clean water need to be replaced every other day.
You're hardly alone. Take the Chairpersons of the United States House and Senate Science Committees. Please.I dont see the need for [frequently changing the water and washing the reservoir]
Rich
This is one benefit to having a small tank, IMO. After 6 espressos/steaming the water is gone, the whole soap thing though.. I have no idea how I would do that - the hole is too small to properly rinse it out. I do however, give it a good rinse every week.
- Sponsor
Keeping things as clean as possible never hurts. But if you're concerned, why not taste a bit of the reservoir water after a week and see?
Personally I try to refill the reservoir based on my demand, so if I'm not going to be using the machine much, just filling half-way or pouring a liter or so in helps to keep water from being in there too long. Or fill what about what I'll use before each use.
I also think it's a good idea to wash out the reservoir regularly (or soak it in a mild cleanser if you can't get a brush inside), as mentioned, algae and bacteria can grow depending on the environment unless you also treat your water with something. Though normal tap water from a city is much less likely for this to happen as it's already been heavily treated usually.
