scottyg514 wrote:Well after 6 months trying with my Vetrano, I'm finally going to change the steam tip.
I've been getting very mixed results with micro foam (mostly unsatisfactory for me) with the stock tip the Vetrano comes with.
Either my milk steams too fast before it gets to a nice Latte art consistency & the results is just thin steamed milk or to over compensate for that I overstretch the milk & the results are sudsy big bubbles.
My definition of a good micro foam consistency is half way through the milk pour it should look like white semi gloss paint being poured into a brown paint try.
I've tried different techniques & I've even tried plugging up one hole with a toothpick. This worked fine a few times but still too inconsistent.
I just think the holes in the Vetrano's stock tip are too big for small amounts of milk (around 6oz), so the milks comes up to temp. before it has time to get to a good texture.
I think I've been patient enough giving it 6 months worth of tries. (at least 2 Lattes a day)
At work we have a Gaggia Coffee with no tip, just a hole at the end of the steam wand & we get perfect micro foam every time with it.
Has anyone had this problem & changed their tip with much better results?
Hi Scott. After 6 months, you've certainly given it a fair shot, so perhaps changing the stock Vetrano 2-hole tip is the way to go. But I've had a completely different experience with my Vetrano. In my hands, the stock tip is well matched to the boiler size, the no-burn wand is a joy to use, and great microfoam is easy to achieve.
Here's a walk-up video I made this morning, using 5-6oz of 1% milk. Nothing special, just my regular routine, complicated by working around a camera on a tripod. Pardon the poor lighting and my pathetic latte art skillz.
[gvideo]http://video.google.com/videoplay?docid=-6920509470066893814[/gvideo]
There really is nothing to it. I recently increased my boiler pressure to 1.3 bars for the Titan Grinder Project, so it only took 15 seconds to froth 5-6oz. IIRC, you're working with twice as much milk, and using whole milk + half & half. The stock Vetrano tip should work just fine for you.
