Suave wrote:Like I said, I am saving up to buy a decent grinder & have learn't from various posts that any old cheap one will not do - over here in London, a decent grinder can cost a fair bit & initially I was a bit concerned to buy a used/secondhand one in case I got stuck with a lemon and/or incase it's useful life was already done or fears that it would need costly servicing or be on it's last legs etc.
They say a picture is worth a thousand words so I have just pulled a shot for you all to see & advise me of - it was done using Pre-Ground Lavazza Black Espresso Coffee (100% Arabica).
As others have stated, the pictures you show are exactly what I'd expect from the coffee you're using. IMO, you won't be able to do significantly better until you've got a decent grinder and are using fresh beans. If you enjoy these results, continue to enjoy them until you've saved up for a decent grinder. If you're not enjoying these results, I'd suggest draining the machine and storing it until you get a decent grinder and some fresh beans. There is no meaningful improvement to be had tweaking things short of that, as far as I can tell.
