I live on a small island on Hawaii and don't have access to a good espresso bar to experience what a correct espresso is supposed to taste like, so I've been trying to make one by reading online and trying to replicate what I see, but I'm having a little difficulty.
Here's my equipment: A Vario grinder, purchased new from ChrisCoffee, and an old Gaggia Espresso with a black plastic shell (
http://partsguru.com/GaggiaEspresso.html) for $10 from a local thrift shop.
When I got the machine it was non-functional from having never been descaled. I disassembled and de-scaled the machine, plugged the "auto-prime" outlet, and have purchased but not yet installed a $40 eBay PID. (I'm still waiting for the SSR.) I sawed off the bottom half of the portafilter holder to make a naked portafilter.
Now everything is working, but the espresso I am getting doesn't match up with what I thought I should get.
Here's my procedure and results:
1) I weigh out 14g of bean (about 8 days post roast) on a .01g scale.
2) I grind the beans in the vario directly into my double shot portafilter
3) I distribute the grinds gently with my finger
4) I briefly tamp with a 58mm tamper with about 30 lb force
5) I insert the portafilter, position a cup, and turn on the machine
6) The moment espresso starts to appear, I start a timer
7) I let the espresso run until the cone collapses (I don't see any channeling), and then maybe 5 seconds more.
...and here are the results:
The espresso appears to be over extracted, but only produces a small 1 oz of product in a short 16 seconds before the cone collapses and blonding sets in.
Here's my thinking. Somewhere I must be doing something wrong, but I can't figure out what it is:
If I extract for a longer time to get more fluid, I go past the blonding point and it seems like I will just have even more over-extracted espresso.
If I grind more finely or tamp harder, it will take longer, but the espresso will be more overextracted and I will get less volume.
If I grind more coarsely or tamp not as hard, it will be less over-extracted and I will get more volume but it will take less time.
It seems like there is no combination of things I can do that will increase the extraction time, decrease the extraction level, and produce 2 oz of fluid. What can I do?
Thanks
-cwm9
