As many of you have probably noticed, the plastic frothing wand that comes with Gaggia machines creates horrible foam (for the most part). I certainly can't dismiss the fact that it may be a lack of skill on my part, but whenever I would put the wand into the cold milk, I would (very soon) get a bunch of unwanted hard and bubbly foam on the top, and it seemed like there was nothing I could do about this.
The remedy: remove the plastic wand! This has been suggested by some here or at CG, and it worked like a charm. I no longer get instantly bad foam at the top and can actually control the steaming. While I'm still not getting perfect microfoam, its quite a bit more flowy (EDIT: smaller, smoother bubbles, but bubbles nonetheless) than the stuff I had before. Note that I am removing the plastic sleeve that works like an extension, not the plastic tip that attaches to the metal wand coming from the machine. I have not yet tried using the metal tip only, and I'm not sure it will be long enough to work. Also, with my 20oz pitcher, I am forced to make two lattes worth of milk so it is high enough for the tip to reach.
Are there any mods people could suggest to make the plastic tip work even better (short of replacing it with a Silvia steaming wand as shown
here)? I have noticed
this thread as well, but I thought I'd vouch for how much better the no-wand setup has been. Please post your experiences.
