another_jim wrote:You need to change grind as the beans stale, because they become less dense, and you use less weight for the same volume. No change is needed to compensate for staling when dosing by weight.
I was discussing this thread with a local barista of the commercial variety today, and there's a point we don't understand.
Suppose our hapless barista always doses by volume, and is working a shift during which the humidity of the cafe rises. He notices that his flow rate has slowed down. If I understand the thread (and analogues of the quoted text above) correctly, this is because the density of the coffee has gone up, so his volume-based dosing gives greater mass, so slows the flow.
According to Jim's suggestion, if he dosed by mass instead, he would get the same flow. But surely the same mass of denser coffee, made so by moisture, now contains less "actual coffee" --- some of what we have there is additional moisture.
So our question: do we expect the taste to be consistent during such humidity changes, if we dose by mass and keep the grind the same? If so, why? We're changing the amount of coffee in the puck --- not its mass, but the mass of the "actual coffee". Does the yield magically change to compensate?
On the other hand, if the taste is going to change despite consistent flow rate, surely it's perfectly reasonable for our barista to re-dial his coffee, to get the shot to be as good as it was when he dialled it in in the morning?
