Freezing Espresso Coffee, Part Two
Link to "Freezing Espresso Coffee, Part Two"by Ken Fox on Thu Mar 19, 2009 12:54 am
This is a JOINT POST of Jim Schulman AND Ken Fox:
On the "Features" section of this website is an article by Ken Fox describing an experiment comparing previously frozen coffee to fresh, never frozen coffee. It concluded that freezing was a reasonable way to preserve coffee intended for espresso use, for a period of at least two months.
There are, however, several potential criticisms: (1) at least some of the tasters were unknown to the online coffee community; (2) doses used for the shots were possibly too large, in the range of 18-20g for a double shot; (3) better espresso grinders might allow more subtle shot differences to appear; and (4), there was no cupping component.
Jim Schulman, although not present for the original experiment, was heavily involved in its design and analysis. He just completed a visit with Ken, in Idaho, and during this time Ken and Jim were able to do a follow up study that addresses these concerns.
This time around, the test coffee used was Sidamo Worka, a delicately fruity and floral coffee that was felt more likely to show any subtle damage inflicted by freezing. The roast profile used was shorter and lighter, completed in 15 minutes to a roast level terminated before the onset of 2nd crack. The frozen test coffees were frozen for a period of 3 3/4 and 1 month . The grinders used were two original Cimbali Max's, of mixed conical/planar design. The tasters were Jim Schulman and Ken Fox, both tasting half the paired shots and with the ability to separate out the results from these two tasters.
Test Design:
One day we compared the coffee frozen for almost 4 months with fresh, and the next day we compared the coffee frozen for only 1 month with fresh. The format was the same both days. First,
we cupped the coffees in a dual triangle test (1 cup fresh/never frozen, placed with two previously frozen and vice versa), and then immediately following we compared identically prepared shots from fresh coffee with those made from previously frozen coffee. All comparisons were single blinded, in that the taster did not know which of the two presented samples was which.Image Dual Triangle Cupping
The test coffees that were frozen were packaged immediately after roasting into plastic valve bags (with the valve taped over), then placed into a very cold chest freezer at around -15F, where they reposed until defrosted in these bags couple of days before the comparison tests were conducted. The fresh-never frozen coffee had degassed for 4-5 days before it was used in the test.
Frozen and Fresh Test Coffees
Results:
In triangle cupping, neither Ken nor Jim was able to identify either odd cup. The roasts for this test was suitable for espresso, rather than cupping, so both the fresh and the frozen had aromatics more subdued than a lighter roast's. It could be that frozen coffee is more detectable in roasts suitable for brewing, but that was not the purpose of this test.
In the espresso comparison tasting, we did sixteen side by side comparisons with the older coffee vs. the fresh never frozen coffee, eight by Ken, and eight by Jim, using a factorial design that alternated the pair of machines and grinders between the fresh and frozen coffees in a balanced manner. We preferred the frozen coffee ten times, the fresh four times, with two ties. The results are suggestive, but not statistically significant, even under the severest statistical torture. On the 2nd day, following its own cupping, we did 8 similar comparisons with the coffee frozen for one month vs. the fresh-never frozen coffee. The fresh was preferred three times, the frozen three times, and there were two ties.
ImageBlind Tasting Espresso Shots
There is absolutely nothing in the results that would suggest that the fresh coffee made better espresso.
Discussion
There are two possibilities that explain our slight preference for the frozen coffee, if indeed that preference was meaningful. The first is the more radical one that green coffee stored in a 50F basement degrades more rapidly than roasted then frozen coffee in a chest freezer. The second is that the flavor of frozen coffee, after being taken out of the freezer, peaks at a different rate than fresh coffee out of the roaster. We may have tasted when the frozen coffee was at its peak and the fresh was not.
But none of this affects the main conclusion, which is: Many things affect the taste of coffee. Freezing has an effect in the same order of magnitude as storing green coffee at room temperature, or of coffee resting in the first week after the roast. Since neither of these is regarded as particularly deletorious to the flavor of espresso, freezing should not be either. Freezing remains a viable method for the preservation of coffee roasted for espresso, for a period of at least 4 months.
Ken Fox and Jim Schulman
What, me worry?
Alfred E. Neuman, 1955
Ken Fox
Link to "Freezing Espresso Coffee, Part Two"by another_jim on Thu Mar 19, 2009 1:03 am
I was surprised by this result. I expected the more floral coffee, the lighter roasts and better grinders would make picking out the frozen coffee easy -- it would be the one that smelt flat, tasted bitter, and had all the other flaws of slightly stale coffee. But that was simply not the case. Instead we split on which coffee tasted rounder, or smelt better, etc. etc.
It seems unlikely that freezing and defrosting has no effect at all on roasted coffee; but I think, given these results, it is impossible to claim that the effect of freezing is larger or more harmful than any of the other things we do with fresh roasted coffee in the first week of its life.
another_jim
Link to "Freezing Espresso Coffee, Part Two"by RapidCoffee on Thu Mar 19, 2009 1:18 am
Great follow-up to the original study! Many thanks for your hard work.
I'm also surprised (but pleased) by the result. To date, I've been freezing coffee on the premise that it's the lesser of two evils (vs. letting it go stale). Now I can freeze my roasts and claim it's part of getting a better cup!
John
RapidCoffee
Link to "Freezing Espresso Coffee, Part Two"by miKe mcKoffee on Thu Mar 19, 2009 1:33 am
I'm not surprised by the results at all. Home use been freezing roasts a couple decades. Pulled quite good tasting shots with copious crema from a full year frozen coffees. One of the big challenges in a commericial setting is how much a batch will change over a week or so use. I solved the problem in my cafe by freezing main blend at 7 days rest. Pull from freezer the day before hitting the grinder. Though in this scenario no long term freezing, usually a week or so.
aka Mike McGinness
www.norwestcoffee.com
miKe mcKoffee
Link to "Freezing Espresso Coffee, Part Two"by peacecup on Thu Mar 19, 2009 4:53 am
I've been freezing coffee ever since I read Ken's first thread, and, my very limited experience notwithstanding, I think freezing works very well. I began from the simply practical point that I can't drink more than one pound in the time it takes to go stale if not frozen, and if I happen to get two pounds fresh its a must.
Why just yesterday I pulled out the tail end of a frozen bag Musetti espresso (the best-before-date kind of Italian beans, but that's a different topic). Considering the age of the beans before freezing (who knows?) and how long they'd sat in the freezer after opening, I expected a "really, really emergency only" cup of brown water. But I was surprised that they produced a quite drinkable espresso, respectable crema and all.
Thanks for the efforts. Now if I could only get you two to try some commercial Italian blends (not Lavazza!), hand grinders, and antique home lever machines....
LMWDP #049
peacecup
Link to "Freezing Espresso Coffee, Part Two"by sweaner on Thu Mar 19, 2009 9:58 am
Excellent experiment. Any thoughts on freezing the coffee in a regular refrigerator/freezer.
Scott
LMWDP #248
Man does not live by coffee alone. Have a danish.
sweaner
Link to "Freezing Espresso Coffee, Part Two"by Ken Fox on Thu Mar 19, 2009 10:31 am
peacecup wrote:Thanks for the efforts. Now if I could only get you two to try some commercial Italian blends (not Lavazza!), hand grinders, and antique home lever machines....
Speaking only for myself, I have no intention of ever doing another study like this, especially about frozen coffee!
ken
What, me worry?
Ken Fox
Link to "Freezing Espresso Coffee, Part Two"by Ken Fox on Thu Mar 19, 2009 10:33 am
sweaner wrote:Excellent experiment. Any thoughts on freezing the coffee in a regular refrigerator/freezer.
As to the use of a refrigerator, I have no experience with them vis a vis coffee preservation and no opinion. As to the use of a freezer compartment in a refrigerator, which will not be as cold as my chest freezers, I'd imagine that you could preserve coffee in them however not for as long a period of time as you can in a truly cold, deep freeze.
ken
What, me worry?
Ken Fox
Link to "Freezing Espresso Coffee, Part Two"by Marty L. on Thu Mar 19, 2009 11:51 am
I freeze coffee from roasters like Terroir, Intelligentsia, and Blue Bottle when the beans arrive by mail (usually within 3 days or so after roast). I freeze the coffee in its vaccum sealed valve bag with the valve taped over, with the valve bag itself placed inside a sealed Ziplock freezer bag. I freeze the coffee in a drawer compartment in a freestanding sub-zero freezer that maintains a temperature of approximately zero degrees F. The drawer is rarely opened and only for a few seconds (maybe 2 or 3 times a week, tops). I defrost (per the instructions in Ken's original article) by leaving the bags sealed overnight, and in the morning when the beans have fully defrosted and I'm ready to brew I remove the tape from the valve and unseal the bag.
Strictly anecdotally speaking, I've kept coffee frozen this way for as long as 6 months and, in both espresso and drip brewing, have never been able to detect any difference between the frozen beans and fresh ones, and once defrosted, the beans are good for a the same period as fresh beans (10-14 days).
Marty L.
Link to "Freezing Espresso Coffee, Part Two"by GC7 on Thu Mar 19, 2009 12:23 pm
This is a nice study. Thanks.
I too suspected that the results would come out as they did based on my past experiences with brewed coffee (not espresso) before I started roasting my own.
I have a question and perhaps a suggestion for improving storage more.
You state
"The test coffees that were frozen were packaged immediately after freezing into plastic valve bags (with the valve taped over), placed into a very cold chest freezer at around -15F, where they reposed until defrosted in these bags couple of days before the comparison tests were conducted. The fresh-never frozen coffee had degassed for 4-5 days before it was used in the test."
The statement implies that you froze the coffee first and THEN placed it into valve bags. If true wouldn't that allow more moisture to accumulate on the beans and also by freezing before placing in the bags eliminate or really slow the degassing which in turn purges the oxygen from the bags? This protocol it seems to me takes away the utility of the bags.
If you insist on using the bags, I might first allow some degassing to purge oxygen, then tape the valve and freeze as quickly as you are capable.
Alternatively, what I do is keep the beans in the valve bag but with the top open and place that into a vacuum bag and seal under vacuum before freezing. I then allow the bags to thaw to room temp when ready to use and only after the first use seal the top of the valve bag for further storage and "normal aging".
Comments?
GC7
Link to "Freezing Espresso Coffee, Part Two"by JohnB. on Thu Mar 19, 2009 12:58 pm
I've been vac bagging(Foodsaver) & freezing my roasted beans for over a year & a half now. I don't have Jim's cupping abilities but I've been very happy with the results. I break the espresso down into 2 day lots & the vac pot/press beans into one use bags. The beans are stored in an upright storage freezer set to 0*F. Just getting into home roasting & I also vac bag/freeze my greens in half pound portions.
LMWDP 267
JohnB.
Link to "Freezing Espresso Coffee, Part Two"by another_jim on Thu Mar 19, 2009 1:02 pm
I'll defer to Ken, but I think it's a typo. He puts the coffees in valve bags immediately after roasting, then freezes them.
The major point of this test, along with all the other accounts we have here, is that coffee in the freezer does not simply go stale more slowly than at room temperature. Whatever happens is different, since the classical signs of staleness (no aroma, flat and/or bitterish taste) do not occur. If freezing does change coffee; it's in some way we haven't been looking for.
another_jim
Link to "Freezing Espresso Coffee, Part Two"by JonR10 on Thu Mar 19, 2009 1:30 pm
Wow, this was a very cool experiment, and nicely done!
Thanks guys - for the effort to help us all understand (or not) just a bit more. Once again, it seems as though more we discover the more we open our eyes to areas that we don't fully undertstand. :mrgreen:
Jon Rosenthal
Houston, Texas
JonR10
Link to "Freezing Espresso Coffee, Part Two"by cafeIKE on Thu Mar 19, 2009 1:58 pm
This was discussed in Rate of coffee staling.
IMO, two months seems fine @ -20°C / -4°F.
cafeIKE
Link to "Freezing Espresso Coffee, Part Two"by GC7 on Thu Mar 19, 2009 1:59 pm
I suspected it might be a typo but confirming would clarify for others.
I do believe that waiting a bit for some degassing in the bags to purge O2 before freezing OR vacuum sealing as I described would improve the process.
JohnB - I love my foodsaver unit. I store any greens not being used within a couple of months in vacuum bags. I divide them up between what can fit into my 57* F wine cabinet and the refrigerator at 4* F. I have not subjected greens to freezing.
GC7
Link to "Freezing Espresso Coffee, Part Two"by Ken Fox on Thu Mar 19, 2009 2:55 pm
GC7 wrote:I have a question and perhaps a suggestion for improving storage more.
You state
The above (posted quite late last night after Jim and I agreed on the text, itself not a simple process!) had a typo in it which I have now corrected. It should have read "The test coffees that were frozen were packaged immediately after roasting into plastic valve bags . . . . "
Thanks for picking this up.
My (Ken's) normal practice is not to use valve bags for freezing my own coffee, rather to use nearly air-tight Mason type jars. The coffee is frozen just out of the roaster in a sealed jar and the jar is not opened again until the jar (or valve bag, in this case) has come back up to room temperature after defrosting, prior to use.
ken
What, me worry?
Ken Fox
Link to "Freezing Espresso Coffee, Part Two"by JohnB. on Thu Mar 19, 2009 5:29 pm
GC7 wrote:JohnB - I love my foodsaver unit. I store any greens not being used within a couple of months in vacuum bags. I divide them up between what can fit into my 57* F wine cabinet and the refrigerator at 4* F. I have not subjected greens to freezing.
Then I assume you meant to say 40*F?? Some good info on greens storage here: http://www.terroircoffee.com/content/view/144/28/
LMWDP 267
JohnB.
Link to "Freezing Espresso Coffee, Part Two"by ManSeekingCoffee on Thu Mar 19, 2009 5:48 pm
Terrific follow up to a great first article. I've been wanting more of this kind of empirical evidence for coffee practices for quite a while. Following your experiences, I typically vacuum seal up surplus beans from the roaster upon receipt and store them in my standard freezer at around 0 degrees (F). I rarely notice any difference between the frozen and fresh beans. In the few instances when I have, my suspicion is careless packing/contamination on my part.
I'm curious about whether you had a chance to follow the frozen coffee out several days post freeze. I typically only freeze a couple of days supply, but I find it hard to believe that there is simply no chemical change to freezing (and aging it). Is the coffee merely in suspended animation. I'd suspect that it ages faster once thawed. I seem to remember this suggestion from the first article as well? Certainly if it did age more quickly upon thawing, that's an argument for bagging up small doses as opposed to an entire bag.
ManSeekingCoffee
Link to "Freezing Espresso Coffee, Part Two"by another_jim on Thu Mar 19, 2009 6:10 pm
ManSeekingCoffee wrote:I'm curious about whether you had a chance to follow the frozen coffee out several days post freeze. I typically only freeze a couple of days supply, but I find it hard to believe that there is simply no chemical change to freezing (and aging it). Is the coffee merely in suspended animation. I'd suspect that it ages faster once thawed.
It's probable that you are right.
Nitrogen pressurized Illy is "progeria coffee," tasting acceptable for a few days, then dying rapidly, almost literally on one's tongue, on the third. However, we noticed no ultra-rapid decline like this. Testing for a slower decline, just like testing for any subtle effect you are not certain of, requires a large number of trials to nail anything (it's easier if one knows exactly what one is looking for, since one can design a far more elegant and telling experiment).
So far, I've been completely incapable of even characterizing how frozen coffee's taste changes in relation to fresh. So the preliminary for experiments of this sort would be for me to cup very light roasted coffees that have been frozen very badly and slap-dash, in the hope of finding an obvious gustatory smoking gun. Once that is found, it may finally be discernible it as a subtle whiff in properly frozen coffee.
It would make a terrific parlor trick, and earn anyone doing it lots of cuppers bragging points. But it would still be meaningless in terms of using or not using freezing when one needs to preserve a roasted espresso blend.
another_jim
Link to "Freezing Espresso Coffee, Part Two"by GC7 on Thu Mar 19, 2009 6:16 pm
JohnB. wrote:Then I assume you meant to say 40*F?? Some good info on greens storage here: http://www.terroircoffee.com/content/view/144/28/
Yep - mixed up my fahrenheit with centigrade :oops:
GC7
Next
Return to Tips and Techniques
