Found tamping method that works!
Postby CST on Thu Feb 25, 2010 6:00 pm
I've been lurking for awhile, trying different methods to dial in my Expobar Lever which I received about a month ago. I finally found a dosing and tamping technique that has given me very good extractions - I no longer want to buy a bottomless portafilter!
For my doubles, I start by dosing two full scoops from the scoop that came with the machine. It holds 8 grams. I've tried dosing more or less and found this to be optimal for my setup. Then, I do the "Joystick" with about 5-10 lbs of pressure. I tilt about 25 degrees all the way around and stop when it looks level. The coffee surface looks packed but really isn't - it is mainly leveled and consistent, especially on the edges. Then I hit the left & right sides of the portafilter with my tamper, once each. Then I tap the top of the basket in 4 locations with the side of the tamper, settling the ground once more. I see some separation from the basket, and some grounds are now laying on top. Finally, I tamp around 30-40 lbs.
My shots have gone from "WTF happpened again?" to quite consistent. Gone are needles, yogurt cups, knives, chopsticks or whatever else I used to use to distribute. Since my dosing doesn't ever reach the top of the basket, leveling by hand never was an option.
Hope this is useful to someone...
-Carter
CST
Postby HB on Thu Feb 25, 2010 6:08 pm
CST wrote:Then, I do the "Joystick" with about 5-10 lbs of pressure. I tilt about 25 degrees all the way around and stop when it looks level. The coffee surface looks packed but really isn't - it is mainly leveled and consistent, especially on the edges.
Indeed, nutating does work surprisingly well. Here's a nice visual from Nutation: how to do it right:
For true nutation devotees, I recommend this tamper piston with the angled sides:
From HB Roadshow - Espresso Tamper Reviews
CST wrote:Then I hit the left & right sides of the portafilter with my tamper, once each. Then I tap the top of the basket in 4 locations with the side of the tamper, settling the ground once more.
Hmm-m, I cannot see the benefit of tapping the portafilter six times. While tapping was very much in vogue at one time, most agree it risks breaking the puck/basket adhesion, leading to channeling.
Postby CST on Thu Feb 25, 2010 6:13 pm
I had been using nutation, but until I started doing the side and top taps, I didn't get consistent results. I'm thinking these extra steps made the difference.
CST
Postby Vad on Thu Feb 25, 2010 6:21 pm
the notion of taps and hits on portafilter is somehow displeasing to me.
Vad
Postby CST on Thu Feb 25, 2010 6:25 pm
HB wrote:Hmm-m, I cannot see the benefit of tapping the portafilter six times. While tapping was very much in vogue at one time, most agree it risks breaking the puck/basket adhesion, leading to channeling.
I can agree this would be a problem if you've already applied a full-pressure tamp, but if you've just very lightly tamped to settled the grounds, probably not.
CST
Postby CoffeeOwl on Thu Feb 25, 2010 6:32 pm
I use a light single smack of the pf against the counter (but it'll be more comfortable to have a tamping stand if using a naked pf).
'a a ha sha sa ma!
LMWDP #199
CoffeeOwl
Postby HB on Thu Feb 25, 2010 6:37 pm
Vad wrote:the notion of taps and hits on portafilter is somehow displeasing to me.
It could be worse:
Postby malachi on Thu Feb 25, 2010 6:45 pm
A simple answer
Any changes to the way you prepare coffee that increase the complexity and / or difficulty of your preparation are almost always due to a problem with your methodology, coffee or equipment (in that order).
malachi
Postby Psyd on Thu Feb 25, 2010 7:12 pm
CST wrote:I can agree this would be a problem if you've already applied a full-pressure tamp, but if you've just very lightly tamped to settled the grounds, probably not.
Regardless as to when in the process, there is no part of it that isn't going to leave your PF and your tamper (depending on who wins) covered in imperfections. Find a nice cushion-y bit to thump the PF on instead of smacking it. You'll be happier this time next year...
Espresso Sniper
One Shot, One Kill
LMWDP #175
Psyd
Postby mgwolf on Thu Feb 25, 2010 10:18 pm
It would be hard to know what the taps are doing or what the nutating is doing without a naked PF.
mgwolf
Next
Return to Tips and Techniques
