Dan,
Thanks! Your routine is very close to the timing I need. Dosing directly into the portafilter with the Versalab, distributing and tamping takes about a minute. Using your protocol I was able to keep things within about 2 degrees at approximately 198 +-1. I think I need to "edge" that up a couple of degrees. At that temperature the espresso is slightly sour.
I pull 2 ristretto shots using the double filter (about 1 oz) for my morning latte. After I get the first shot right (maybe a slightly shorter flush?) then I have to figure the second one out - at that point the machine has not been resting so the flush will be different.
The espresso? There are mornings when I'm really happy - and I achieve a really rich, sweet cup. More often than not I'm a bit on one side or the other of where I'd like it to be. I suspect ultimately a machine with temperature controlled in degrees fahrenheit is in my future. Over the last six months I've improved my tools and learned to manage many of the other variables (dosing, tamping, fresh coffee, grind) pretty well. I'm inclined to believe temperature is the major issue left to get more repeatable results.
Thanks for spending time going over what I know is old territory for you. It helped move things ahead. I really do like a good latte in the morning.
HB wrote:hperry wrote:The best stability I've got so far is to flush again - this time just until the dance ends.
- Flush to usual brew temperature (~six ounces)
- Leisurely prepare your basket in around a minute
- Flush barely two ounces, just a teenie bit past the water dance end
- Lock in the portafilter. Face towards Seattle and say a short prayer to the Espresso Gods (10 seconds have passed since step 3)
- Go.
Oh, with all this flush minutia, I forgot to ask: How's the espresso taste?
