by espresso2010 on Sat Apr 24, 2010 10:24 am
Does anybody know if it's normal for Silvia (v3) to pick up speed throughout the extraction? I've been having this problem for the past month that I've owned it, where the flow starts out slow and ends up faster and curly. I can't tell if it's normal or a sign of channeling. Practically every shot I've pulled has been like that. I've suspected channeling, but have been trying all kinds of tricks in dosing/distribution/tamping/temp surfing per forum tips and posts, and still get the same pattern of flow. It's never the same consistent rate from beginning to end. I was wondering if it has anything to do with lack of flow restrictor on these machines.
I have recently turned down the OPV half a revolution and obtained a 14-g ridgeless basket, which has helped my shots be more consistent but the flow speed still picks up during pull no matter what I do.
Another question I had is why does the extraction break up sometimes, whether it's high flow (normale) or low flow (ristretto)? i.e. I don't get a steady continuous stream.
I have a Gaggia MDF grinder (set to either 2 or 3), I dose anywhere between 15-17g with a ridgeless 14-g basket (espresso parts), and my beans are roasted locally and they are typically 4-14 days old when I use them.
I appreciate your help.
