by portamento on Fri Mar 06, 2009 1:39 pm
I would say the crema on my shots always tastes worse than the underlying liqueur. I would say ashy is the most prevalent flaw.
I don't find the flavor objectionable once the espresso is stirred, swirled, or transferred from shot glasses to a 5oz cup. If I pull directly into the cappuccino cup, I swirl the espresso before pouring latte art. Otherwise the first and last sips of the drink will be unbalanced.
I wonder if some equipment factors exaggerate this phenomenon; in my case:
- vibe pump e61 with slow preinfusion
- HX temperature hump
- flat burr Mazzer Mini that gives up a lot of solubles according to Jim's observations
It seems that all of the above factors contribute to a "front-loaded" extraction.
Could it be that a La Marzocco where the first drips are immediate and the temperature profile is flat serve to mitigate the crema balance issue?
Furthermore, wouldn't a "titan" conical grind tend to release solubles more steadily than my grind, as evidenced by a lighter-colored start of the flow and later blonding? (In contrast to my Mazzer Mini shots, which start dark and slow, then accelerate in the middle of the extraction.)
Or Malachi, are you saying that the crema generally tastes bad even in good espressos, so I should stop analyzing and keep stirring?
