dsc wrote:so the pucks gets more dense and is compressed during the shot. Where did the statement 'the puck expands during the shot' come from then?
dsc.
Yes, the internet is inaccurate, but not in the way Chris thinks.
M Petracco in Illy's Espresso Coffee
7.5.1 Ground Coffee Portion ... "Maximum (dose) values are often encountered in home brewed coffee, as the host inclines to overdose to offer the guest the best possible coffee cup. This practice is risky because, as will be seen in 7.5.4, an excessive amount of coffee does not permit sufficient puck expansion during cake wetting."
7.5.4 Cake Shape ... "An important phenomenon to be taken into acount when considering the shape of the cake is the expansion of the bed due to swelling of coffee particles when wetted .... During expansion, the wet coffee grounds exert a pressure comparable to wooden wedges used in the past to cleave stone (highlighting added by me) ... On account of this behavior, an empty space is left over the coffee cake"
The idea that the puck compresses under pump pressure is "barista hearsay lore" based on a post on PF net or some such that someone somewhere saw a glass PF and that the puck got smaller except at the end, when the 3 way whoosh expanded it. I hate to quarrel with imaginary glass portafilters, but as the quote asserts, water and hence water logged coffee particles are incompressible, and also the pressure gradient on the puck is very small, since most of the drop in pressure occurs at the bottom, where the fines are. In other words, the compression force of the pump is small, and the expansion force of the waterlogged particles is huge.
So on the internet, hearsay and peer reviewed information seems to get inverted.
This is not to say that this Petracco chapter is gospel; it has some very big inaccuracies. Puck expansion does account for the greater technical difficulties and skill levels required for successful updosing. A low dose puck is not locked in place, and the breaks and gaps that cause channeling heal themselves during the shot. Overdosed puck's particles are locked into place and gaps do not repair themselves.
But according to his account, there is no such thing as successful updosing:
" ... disturbs percolation and causes the deposit of coffee solids in the cup"
Vague as this is, it isn't true about properly updosed shots.
