DennisS wrote:to make a flat disc of paper like the type used in the Illy pods to place on top of the puck after tamping and before pulling the shot...anybody know where to get or how to specify such paper?
ds
This sort of disc can be easily obtained from any laboratory supply company. It is referred to as Buchner funnel filtration paper. It comes in all imaginable porosity and diameter combinations. I imagine you would want the coarsest possible type.
Problems I see with this approach: the added flow restriction of the filter paper will affect the flow rate of the espresso and change the overall extraction profile. The sides are unsealed, so the water may be forced to channel around the filter paper. It won't keep coffee oils from getting to the screen, which will still need some maintenance.
Then again, pods seem to work fine. Maybe this would work, too. It might be worth a try. I would get some pods first to get an estimate of what the appropriate filter type would be. Maybe you can even try disassembling a few pods and placing the empty pod paper on top of your tamped espresso first, just to see how it works.
