Filter paper between puck and grouphead - Page 2
Postby DennisS on Sun Apr 05, 2009 12:34 pm
so where do you get them matias ?
ds
DennisS
Postby mathias on Sun Apr 05, 2009 4:47 pm
Standard filter cones for making filter coffee, size N°4. I staple two of them together, there is enough space to draw three circles and then I just cut with a pair of scissors. That gives 12 discs.
mathias
Postby texican on Mon Apr 06, 2009 12:12 pm
I use a poly filter that was recommended by Rasqual for use with an Aeropress. The filter allows complete oil extraction with no fines. Your post has me thinking it might work for use in my Cremina. I'll give it a try today and let you know the results. The poly filter comes from McMaster. Very inexpensive stuff.
Steve in Ft. Worth
"Hand me another one of them thar brews..."
ZZ Top song MEXICAN BLACKBIRD
texican
Postby mathias on Mon Apr 06, 2009 12:35 pm
texican wrote:... with an Aeropress. The filter allows complete oil extraction ......
Steve in Ft. Worth
Perhaps good for the aeropress but for this purpose a filter that does not let oils pass would be better since the idea is to keep fines and oils away from the shower screen and piston cylinder.
mathias
Postby texican on Mon Apr 06, 2009 3:55 pm
drdna wrote:
Problems I see with this approach: the added flow restriction of the filter paper will affect the flow rate of the espresso and change the overall extraction profile. The sides are unsealed, so the water may be forced to channel around the filter paper. It won't keep coffee oils from getting to the screen, which will still need some maintenance.
Well, based on my limited observations I think the use of a poly-felt filter may become a fixture in my shot-pulling routine. :D
Here's what I did:
Using a Cremina filter basket, I lightly traced a circle on the poly-felt material. Then, I cut inside the circle to fit in the basket. Following my usual routine of grind, WDT, Stockfleth, Staub tamp I placed the poly filter on top of the puck and pulled my shot (SM Liquid Amber). The shot was thick and creamy with the same characteristics as my subsequent shot without the poly filter.
The major difference is that after using the poly, the were virtually no grinds in the grouphead. I still performed my cleaning routine with a grouphead brush, wet paper towel and a cleansing flush to purge the oils.
I performed an identical routine using a poly filter cut to fit a standard 58mm basket for my Sirena semi-auto (Big thanks to Roastarama for his terrific tutorial!). I grind a bit finer for the Sirena but the shot came out fantastic. Loads of crema and full of fruit and sweet, smoky caramel. Flavor profile was identical to the shot pulled without the poly filter on top of the puck.
There was, however a difference in post-shot cleanup from the Cremina. With the Cremina, the puck was solid and the poly filter was completely dry. With the Sirena, the poly filter was stuck to the grouphead and the puck was slightly soupy. This may be a result of the Sirena not having a three-way solenoid. There were a FEW grinds left on the grouphead but I think perhaps that was due to me cutting a little too much inside the circle that I traced on the poly. :oops:
Anyway, my extremely early conclusions lead me to believe that using the poly filter greatly reduces grind retention residue on the grouphead. I'll still follow my regular routine of flushing the grouphead but like the OP, I usually flushed two or three times to clean after pulling a shot. Now, I only have to do one short flush. The poly filter seems to not restrict flow extraction and thus not alter flavor profile while simultaneously greatly reducing post-shot clean up.
I admit that my cupping skills are probably not up to most folks on this forum however I'm pretty sure I can taste the difference in an "apples to apples" comparison where the only variance is the poly filter IMOHP.
Questions? Suggestions?
Steve, in Ft. Worth
texican
Postby mathias on Mon Apr 06, 2009 4:29 pm
Steve, you say cut to fit in the basket. Try to cut a disc large enough so you can place it on top of the basket. If you rinse it before and just dry it by folding it in a towel it will still be damp and easy to place on top. If there is a difference I'd say you have less or no grinds at all on the shower screen. At least this is the case with a filter for making filter coffee and my Cremina.
mathias
Postby DennisS on Mon Apr 06, 2009 7:06 pm
There are punches known as Arch Punches that could cut a nice circle with one whack of a hammer, i use them all the time, you could stack up a bunch of sheets and do it on a cutting board
MSC has a bunch, i am sure McMaster Carr does too
but please tell me more about the poly (felt?) material like a part number or something ?
thanks
ds
DennisS
Postby texican on Mon Apr 06, 2009 9:38 pm
Dennis, the poly filter can be found at this link http://preview.tinyurl.com/x39j. There's thread on CG at this link http://preview.tinyurl.com/cr6avj that discusses the material. You can also do a keyword search on Aerobie Aeropress at the CoffeeGeek website. I'll keep experimenting with different sized cutouts as suggested by Mathias.
Steve, in Ft. Worth
texican
Postby DennisS on Tue Apr 07, 2009 12:57 pm
thanks for the info Steve
some is on the way
McMaster is a pretty amazing web site
ds
DennisS
Postby cannonfodder on Tue Apr 07, 2009 8:48 pm
It is a novel idea but I dont see a reason for it. The water pouring onto the puck is no more violent than a rotary pump machine. If you do a second pump on the lever you are not going to suck much into the piston and anything that does get pulled in will be purged when you pull the shot. I used (and still use) a lever for several years and never had any noteworthy buildup on the piston when I would clean them and that was only once or twice a year. It just seems like a solution looking for a problem, but to each his own.
cannonfodder
PreviousNext
Return to Tips and Techniques
