pgottstein wrote:Everything I read says 24-27 seconds for a 2oz shot. How long should a triple shot be. Same amount of time or say 34 seconds. Does anybody know.
What gets extracted from the grounds is a function of heat and water solubility. At the same temperature, desirable solubles are being released by heat and water in (roughly) 25 - thirty seconds. Less, and you're not getting all the good stuff (under-extracted), longer and you're beginning to get some of the undesirable solubles (over-extracted).
This is true whether you're extracting six grams, or sixty, as espresso. OTOH, it does take longer for the 22.5g puck to saturate than the 6.5g. This is why you'll hear people saying things like the double tastes better than the triple, two singles taste far better than a double, etc. Within a puck, there will always be a teeny extraction differential between the top of the puck and the bottom. The large the puck gets, the larger that differential will be.
Or at least that's how it seems to me...
