Extraction issues- Vibiemme Double - Page 7
Postby Marshall on Thu Nov 20, 2008 8:25 pm
cafeIKE wrote:Of course, it could have been the extra particulates from the fires :cry:
Here in Southern California, this week was an excellent opportunity to experience the very last flavor on the Ted Lingle/SCAA Flavor Wheel: "Ashy." He categorizes it as a "dry distillation." You normally don't reach it until the most over-extracted drop of your over-extracted coffee reaches the cup. Yum!
Marshall
Los Angeles
Marshall
Postby buzzmc on Thu Nov 20, 2008 9:21 pm
So this always chokes the machine. But this time I let it go for a while. finally something hits the cup (likely time elapsed, 30-45 sec before a drop made it to the cup).
I let it go for a while more.... Certainly not a textbook shot.
Results:
Color much better.
Taste much better.
Temp pretty low... And this is into one of those clear, double walled bodum cups.
So I'm sure I'm missing a ton of variables that are needed, but this makes me wonder if the pressure is significantly off on the gauge on my machine - But maybe I'm incorrectly assuming pressure affects flow...
And I have no idea why the temp was low. It was a lukewarm shot at best, but it also took forever to get into the cup, so maybe this is not much of a concern. Certainly my faster shots are much hotter than this.
buzzmc
Postby shadowfax on Fri Nov 21, 2008 1:55 am
Ahh, the classic ultra-ristretto.
I think they're easy to pull (obviously), but you sacrifice a lot--while the shots are, indeed unobjectionable and indeed sometimes rather nice, I think you'll find, when you experience it, that a nicely done normale, or even a normal ristretto, will have a lot more interest and nuance to it. As far as the temperature--you said you didn't even get drops for 30+ seconds. A slow shot means more time to sit out in the cool air, to cool off in the cup, while more is brewing. Such a shot is so slow that it cools off while it's brewing a lot more than a normale would.
I doubt there is anything wrong with your machine. You just bought one of the best grinders money can buy, and you have one of the nicest home machines money can buy. Let's just say it's all your fault. ;)
You need patience and more analysis of yourself and your coffee--less of your equipment. You paid a lot of money to do just that, and you ought to enjoy that. You have a dial to adjust temperature, and a dial to adjust grind. Get your dosing consistent, and go forth and make espresso. Carefully. You've got nothing left but self-doubt now... the blessing and curse of such nice toys...
Nicholas Lundgaard
shadowfax
Postby buzzmc on Sat Nov 22, 2008 1:43 am
3 bags later, much frustration has been at least temporarily relieved.
I've been coarsening (?) up the grind slowly, and I think I've got it now to where I need to play with the temp on the machine for this particular bean - But I pulled 4 drinks this evening with all of them being a much different extraction than I'm used to. 3 latte's and I pulled an espresso for myself, and the epsresso was drinkable for sure... I think maybe a tad hot is all.
Richer, thicker, darker pulls. One night does not make success, but I'm betting/guessing that this won;t change much.. At least that was the plan for purchasing this grinder anyway. I'll be uber happy if this ends up being true.
What's more: The old grinder's grinds appear and feel finer than the new one, but I couldn't get shots to pull slowly/correctly. Pretty interesting.
I'm feeling a lot less frustrated now - Thanks to all for the help.
buzzmc
Postby networkcrasher on Sat Nov 22, 2008 11:55 am
What temp are you running?
networkcrasher
Postby buzzmc on Sat Nov 22, 2008 12:09 pm
PID reads 223 right now, which was a setting recommended when I started having issues... And I've never read that someone has an answer for the temp drop from the PID readout to what gets to the puck.. But people were guessing it was around 10*, which should mean that my temp's still somewhat high.
buzzmc
Postby networkcrasher on Sat Nov 22, 2008 12:14 pm
I'm running at 102*C.. I wish I could get ahold of a Scace to test it, but haven't yet.
This is what another owner told me...
Still working on it. Set your PID +31 degrees over what you want your brew temperature to be and flush 10 ounces of water through the group before you remove the portafilter and start preparing your shot. That should get you the temperature you are looking for.
networkcrasher
Postby buzzmc on Sat Nov 22, 2008 8:55 pm
+31.. Yowza. 203+31=234, so I'm way under.
Complicated little concoctions these are.
buzzmc
Postby networkcrasher on Sun Nov 23, 2008 12:21 pm
I forgot to add YMMV :-)
networkcrasher
Postby buzzmc on Sun Nov 23, 2008 2:10 pm
networkcrasher wrote:I forgot to add YMMV :-)
Well that's just not right :mrgreen:
Last night I tried 234 on the display, but I think the heater turned off for some reason on my machine... The pull was dishearteningly light in color, and I tasted it anyway, which then made a lot of sense as it was barely lukewarm.
I'd love it if I could compress time and figure this out in short order, lol.
buzzmc
PreviousNext
Return to Tips and Techniques
