buzzmc wrote:Heh.
Last call for me if there are any good ideas left for trying to determine if my grinder is really the culprit in my extraction woes..
Summary, after scale, always seem to be 18g doses, and about every 10th pull or so I get a decent shot, but mostly I get thin, and light colored pulls.
Assuming you are not trying to pull shot after shot after shot in short order. Doing so will cool the bottom of the boiler and you'll end up with cool shots, which could account for the light color.
Stale coffee can deliver weak thin shots. Some coffees are only good for a week after roast.
The ground coffee should feel like fine sugar and stick between your fingers.
IMO, 18g is too much. 16 is about as much as I go on a double with quality fresh coffee. Grind finer, tamp lightly. When you get 60 ml in 30s after the first drop, you're in the ball park.
