Hi,
Got an the Expobar Office Control a few weeks ago, and I have been learning how to use it
I have added the thermosyphon restrictor (got it from WLL)
Installing thermosyphon restrictor on expobar office pulserI also have added Eric's adapter, along with a type K TC, connected to a cheap meter for now. I eventually plan to build a TC4 + Arduino + LCD, all mounted under the machine, to use to read temps.
Idle temp this morning was 212, after maybe a 1 hour warmup.
I had expected/hoped for short flush times with the restrictor.
To get to 185 at the grouphead, I need to flush for around 30 secs, and about 10 ozs.
BTW, I did calibrate my TC/meter. Based on the barametric pressure reading nearby at the time (29.99), I figured I was right at 212 boiling temp, and my meter read 204 when placed in a pot of boiling water/steam, so I correct by 8f.
I have also adjusted my pressurestat down. Last time I checked, it was peaking a 1 bar, but I have adjusted it lower since, I am probably less then 0.9 bar now. I have to hook up a hose/meter to the steam arm to check it, and I have been too lazy to do it lately. I don't steam much, and it steams fast enough right now, so I wasn't that worried about the absolute pressure.
Just wondering if anybody had any ideas why my flush is still so long, or what else I could do to help reduce it?
Otherwise, I just ordered a float valve. I don't think the long flushes would bother me as much if I didn't have to fill up my tank every couple of days.
Randy
