jasonmolinari wrote:My goal is to theoretically pull a shot without water dance.
Boiler pressure settings and the resultant brew temperature for one HX espresso machine don't translate well to another, even if they both have E61 groups. That's because manufacturers tune the thermodynamics of their equipment by altering the HX volume, HX injector length, HX/cold water mixing, thermosyphon restrictors, and delivery/return leg lengths/diameters to produce the desired temperature mixing. Eric's data for the Quickmill will be especially difficult to apply to your Isomac since the Quickmills vent water through the over-pressure valve from the
hot side of the HX whereas yours vents cold water immediately after the pump.
jasonmolinari wrote:Oddly though, i'm still getting water that flash boils when i pull from the group. That doesn't make much sense to me! The thermocouple in the group shows it's idling at about 201 or so.
See this
Saturated Steam Table. Your boiler pressure reading of 0.7 is 1.7 bar absolute; the water's temperature is thus 239°F. The grouphead measurement is lower because the thermosyphon is not 100% thermally efficient and the whole system is radiating heat. Still, the cooler grouphead may not be enough to initially cool the super-heated HX water below the boiling point of water at room pressure, hence a moment of flash boiling.
In other words, the idea of lowering the boiler pressure isn't to fine-tune the HX per se, but to have the grouphead idle near the desired brew temperature. A short flush of flash boiling may be just enough to equalize the group, since it's going to be hotter at the flat back of the grouphead than the tip of the saucer.
