Beezer wrote:GC7, you may want to try a different steam tip for your Anita. I had trouble steaming with my Anita's stock tip, but it became much easier (though also somewhat slow) with the two-hole tip from espressoparts.com. Later I upgraded to the four-hole steam wand for the La Spaziale, and the speed and quality of the microfoam both improved greatly. However, for a cheap fix the espressoparts tip is very effective. It's certainly cheaper than buying a new, high-end pitcher, and more likely to give you good results.
I keep forgetting there is an older version of the Anita in the wild. Anyhow, I am a little confused here, I just got my Anita about a week ago [assuming the "new" version ] Anyhow, the tip that came on it has two holes, how does that differ than this one (below) ?
Beezer - thanks for the tip on the 4 hole tip
