Espresso pack saturation measurement.
Postby Ron on Sun Jun 26, 2011 11:30 am
I was wondering how common it is to compare the weight of the pre-shot espresso pack with the post-shot weight. It seems to me that this might be a good way to check saturation. Once all the excess water drains out of grounds, too light a post-shot pack weight probably would indicate channeling or failure to extract from a percentage of grounds. Today I had a very decent shot on a Magister HX (MS-40) and went from something like 15 grams to 28 grams pre- and post-shot.
Have others measured this much? Is there a thread for this? Sorry if I have posted about something that has a lot of discussion already. I just got interested in this again after doing a very belated brew head gasket change which made my machine behave like it was new again.
Ron
Ron
Postby cannonfodder on Sun Jun 26, 2011 10:42 pm
No, it is not a common thing. The only person I know of that has tried to calculate the extraction based on the post extraction weight was Jim. To really tell how much solids were extracted you would need a humidity meter and a very accurate scale. Not the $12 ebay specials. You would have to get the moisture content of the coffee before the shot, then bake the puck in the oven to dry it out to the exact same moisture content. Then you could use your $600 calibrated scale to weigh the pucks to see how much solid material was extracted. Lot of work.
cannonfodder
Postby another_jim on Sun Jun 26, 2011 10:57 pm
The water content is just as meaningless as most other post shot features of the puck. To check extraction, the pucks need to be baked for several hours until they are bone dry (the fresh cofffee also needs to be treated the same, since there is residual moisture, usually 1% to 3%)
The only post shot moisture variable is that down dosed pucks look soggier than updosed pucks, and that is simply because there is more water in the basket when there is less coffee.
another_jim
Postby erics on Sun Jul 03, 2011 10:27 am
It is not a common ritual but is discussed here: WBC Procedure for Measurement of Brewing Water Temperature - see section 4.3 . Other than trying to come up with a good number for total water flow, I can't think of a purpose for this measurement.
Skål,
Eric S.
http://users.rcn.com/erics/
erics
Return to Tips and Techniques
