by robbbby on Wed Apr 20, 2011 7:21 pm
Hey guys, i'm trying to figure out where the error in my coffee making is.
My father and I use the same beans, we generally split bags to keep things fresh.
When making espresso at his house it comes out beautifully, nearly the entire cup is crema and if you let it sit the crema stays there forever.
When I try using the same beans it's not quite the same. Taste is very good and closely resembles when made at his house but the crema is not nice and thick. If you let the coffee sit for a minute the crema disappears.
Now he has some older equipment, a baby gaggia with a matching gaggia bean grinder. He is a set it and forget it type of guy, he has not adjusted the grinder since he bought it 10+ years ago. He is also old school, doesn't clean the equipment (backflush, decalcify, clean grinder, etc.), simply rinses the portafilter and head after use.
I myself have a baratza vario grinder and a lelit pl041 machine (place I purchased it from no longer sells lelit, that kind of scares me). Now I don't know if my problem is having so much control with the vario but I have tried so many combinations of grind size and coffee amount.
I currently have it set to almost the absolute finest setting and use a grind time of 8.5 seconds.
One thing i've noticed is that when starting the coffee comes out perfectly for the first half and suddenly picks up steam and starts coming out much too quickly for the remainder which I think is passing too much water into the cup.
And one last thing also, I find that as soon as the second stage of the espresso making kicks in (when it starts pouring out much too quickly), i'll get drips on the outside of the portafilter. I know I don't have too many beans since the handle can easily twist all the way around with a nice snug fit. I've tried coarser grinds, more/less beans, light/heavy pressure tamps and still get the same problem.
Like I mentioned, right now it is pretty good but still not perfect like my pops.
Any suggestions?
