samster wrote:i get more sprites on the single shot than the double. anyone out there know if this is the norm? thx
It takes time to get to know new equipment.
By sprites, I take it you mean "spritzes" or coffee spraying out of the bottom of the basket at an angle other than straight down into the cup.
Yeah, I would say it's generally more difficult to prepare a single than a double. There's been lots of talk on this board and others about that. But it can be done with some care and patience. My advice is to pull doubles until you get the hang of your new equipment, then work on your singles technique.
I would also advise skipping Black Cat for now and picking up a more widely appealing and forgiving blend like Metropolis Redline. Try it at their recommended brew parameters, but also try it at lower doses. If that doesn't produce good results, pick up a lightly-roasted single-origin from Terroir and see how you do with 14g doses.
Presumably, you're using the GS/3 paddle's capability to do pre-infusion. Make sure you develop a consistent routine for this. The typical method is to pre-infuse until you see the first drops of espresso appear on the bottom of the basket.
What grinder are you using?
