I'm still new to the terminology and techniques, but have had a lot of fun trying little tweaks here & there to get good shots. But I'm stumped by one issue in particular: my shots tend to go blonde (or at least, my perception of blonde) very quickly, often within 10 seconds of turning on the pump.
I ran an example to document here. The shot started going blonde about 15 seconds after I started the pump, and here's a shot 24 seconds after I turned on the pump (I started the pump about 1 second after I started the timer). As you can see, it's incredibly watery. The resulting shot volume was a little less than 3oz, and I would characterize it as bitter, like a very hoppy beer.
I used about 14 grams of coffee, ground on setting "3" of the grinder. I've tried finer grinds, but the filter tends to clog. I used the "double" sized basket.
(One other note: The filter basket has one hole, directly in the middle, and the portafilter itself has a plastic insert that I assume is a crema enhancer. I've tried running without the enhancer, but since the basket has only one hole in the middle, the pour literally shot right down the middle and out the screw hole. The resulting mess took a while to clean up.
I tamped N-S-E-W with relatively light pressure, then in the center with 30 lbs, holding it for 5 seconds. Then a polishing tamp holding down with about 5-10 lbs of pressure while turning the tamper 360°.
Thanks in advance for any pointers you may be able to give me, and thanks for this website-- it's a great resource with an overwhelming amount of information!
